89 E350 weight infos needed
Old Jan 2, 2014 | 03:33 PM
fastfred49's Avatar
fastfred49
Hi all and happy new year!
I'm looking for technical infos about my RV '89 E350 460 ci for the homologation in France.
It has a c6 trans without OD.
I found GVWR, GAWR front & rear, but I need the max weight with trailer (max authorized trailer weight in fact).
I need infos about the engine too : max torque, max engine speed.
I found info about the power with a value of 108 kW, is it correct ?
Thanks in advance for the help.
Best regards,
Fred
Old Jan 2, 2014 | 05:04 PM
jayro88's Avatar
jayro88
I have an '88 E250 with a c6 and 3.54 gears. This is what the factory manual says about the GCWR (van+trailer).
With 3.54's it is from 10k-15k, depending on your hitch setup (frame mount, weight distribution, brake controller etc)
With 4.10's it is from 11k-18.5K depending on your setup.
If you want I can scan my manual page and email it....if it would help. Basically, subtract the weight of the vehicle from the GCWR and you get your trailer weight.
Though if yours is an RV with a Dually axle etc it could be quite a bit different.
Old Jan 4, 2014 | 01:08 PM
fastfred49's Avatar
fastfred49
Hi, Thanks for your answer.
I don't have hitch on. Your info would be sufficient.
I will study that with the office responsible of the homologation.
jayro88
13
Mar 21, 2015 09:00 AM
Mama Paz
2004 - 2008 F150
Jun 6, 2010 09:33 AM
Chris89lx
All Things Towing
18
Mar 27, 2009 04:12 PM
flitchplate
All Things Towing
Apr 25, 2005 08:26 PM
horsehauler
All Things Towing
Oct 9, 2000 10:38 PM
