Engine light on after battery replacement
As Tedster9 noted .....
Don't forget to follow the instructions in the owner's manual regarding changing and/or the battery and the need to rest the BMS (Battery Management System).
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?
BTW .....
And ... Your vehicle IS?
HINT/TIP: Put your -COMPLETE- vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
Maintence » CHANGING THE VEHICLE BATTERY » Battery Management System ...
*NOTE: FoMoCo dealership service can reset the BMS using their IDS (Intergrated Diagnostic System) negating the eight hours of vehicle sleep time requirement.After battery replacement, or in some cases after charging the battery with the external charger, the BMS requires eight hours of vehicle sleep time (key off with doors closed) to relearn the new battery state of charge. Prior to relearning the state of charge, the BMS may disable electrical features (to protect the battery) earlier than normal.
Owner's Manuals ««« -click-
» Select Your Year [ Choose One ]
» Select Your Make [ Choose One ]
» Select Your Model [ Choose One ]
.» Select Your Year [ Choose One ]
BTW .....
joe f350
23
02-01-2009 11:26 PM
