Emergency brake help
Please Help! I have a 1985 F350 dually. It has a 7.3l, and a T19. How do I adjust the emergency brake?
Details: the emergency brake is connected, just needs to be adjusted. When I step on the e-brake, it pushes to the floor. Sometimes it holds, sometimes it does nothing. Same when I pull the release. Sometimes it releases, sometimes it does nothing. But you can see the cables running along the side of the frame, and the cables wiggle & shake when you press/pull the e-brake & release (so they are connected). What do I do?
Thanks for the tip @cuba
ibrant
12-29-2003 04:04 PM
