ok thanks, I don't think mine are right. I couldn't get the 4 holes to all match up to the holes in the wheel well rim. There was no way. I tried several times, I think the idiot ordered me the wrong pair. just pissed because I gave him the exact serial number to order and it does not match up on the plastic wheel liner..this is when you want to go in an scream at the idiot. wasted my time and effort with wheel wells that are not right..I will be at dealer first thing tomorrow.
At the risk of suggesting you're not installing them correctly, did you loosely install all four outer wheel well bolts before tighten? Makes it much easier to adjust as you go along. I did have some small difficulty with those and just started all until all four were on the threads and then tighten each. Once those four were on and tight, the two wedge anchors and four clips were a piece of cake.
I couldn't get but 2 to line up. the other 2 were below the holes on the truck metal wheel lip. I sat and tried both fenders. Let me ask you, which fender went on your passenger side wheel wheel , the RHS or LHS wheel liner.. I tried them both, seems these didn't line up all 4 holes. each time I tried line up one side the other side was off. I looked at diagram and it is no that difficult,, I only wish you were able to read the part# off the back of your liner that would tell me but I am bringing them back in morning and we will both look at computer to convince me there the right liners. I think there wrong but I will see in the morning. I did think they provided pretty good coverage, at least enough to keep the dirt/salt from going everywhere.
Jimmy glad yours went in right. I was trying to put mine in and they just wouldn't line up for all 4 screws, kept looking at it and said this cant be right. Well after a few tries I took them out and looked at part #. This knucklehead at dealer, even after I gave him the rigeht part# orders me part
BC3J-9928371,, the Ford Accessories page says BC3Z-9927886A for SD 2011-2014. No wonder the holes don't line up..Jimmy can you tell me what part# you had on your wheel liners? Are they the BC3Z? Thanks
I knew it, that dumb *** at the dealer,,cant even order what part number I gave him. Thanks Jim, this is helpful.. I am heading over there in a few minutes..
Jim, dealer guy said they the right ones, I showed him that the 4 holes did not match up to the 4 pre-drilled holes on the wheel well rim. Can I ask you when you installed yours did all 4 holes line up perfectly to your wheel rim? He is ordering a new set just to make sure someone didn't slap wrong sticker on liners. He will call me tomorrow..
All four lined up with no problem. I did have to search around for the clip nut and that's why I said wait till all four are started before tightening. To be clear mine are "BC3Z". If these don't lineup, have him order that part number. It really is that easy to install.
z
the sticker said BC3Z but I dont believe it was the same liner. he is ordering a new set and said they would come in today..we will see.
He ordered another pair and was exact same as what I had, I am gonna try again,, I must be a bonehead or missed something on the install. The left side lined up better than right,, I guess 1 more try..Any advice on the install?
