battery cable ?
Old Jan 1, 2014 | 05:15 PM
mknapik's Avatar
mknapik
battery cable ?
Where does the driver side battery connect to if its not conne ted to the passenger side battery terminal. The previous owner had them ran a different way and can't figure it out .
Old Jan 1, 2014 | 06:11 PM
tjc transport's Avatar
tjc transport
i ain't rite
driver side negative goes to the block. driver side positive runs along the radiator support and connects to the passenger side battery positive post connector, then down to the starter.
Old Jan 1, 2014 | 06:17 PM
mknapik's Avatar
mknapik
Okah that's how I'll run them . That's now they had them so I wonder where it was . I wish j would have paid attention to where they had it .
Old Jan 2, 2014 | 01:34 AM
airdale94's Avatar
airdale94
Both negs. go to a seperate ground (eng. block). The pos.'s have to be conected to each other then to load (parellel circuit). This doubles the amps but keeps the voltage at 12.
Old Jan 2, 2014 | 01:42 AM
mknapik's Avatar
mknapik
I have one ground to block other on trans bolt to block is this sufficient enough and now have the batteries connected to each other . Thanks for the help
Old Jan 2, 2014 | 10:57 AM
airdale94's Avatar
airdale94
It should be fine. I think the correct place is on the front left and right lower sides. Not sure how you ended up with enough length to go to the back.
Old Jan 2, 2014 | 11:24 AM
mknapik's Avatar
mknapik
They were custom 2/0 made cablesby previous owner .The positive fro the driver side was connected different to is wasn't in the battery terminal and it threw me off when I started hooking all the electrical back to the motor . Thanks for the help again guys never fails to ask a question no matter how stupid it may seem and somebody will point you in the right direction
Old Jan 2, 2014 | 11:47 AM
lindstromjd's Avatar
lindstromjd
Well, it's an important question to be asked when dealing with dual batteries. If you hook up two batteries in parallel, which is POS to POS and NEG to ground, then you get double amps and keep the volts the same. If you hook up in series, which is POS to NEG, then you get double volts and keep the amps. So not a "stupid" question in my book. Just one that takes a little understanding of how batteries can work.
brider
May 31, 2012 02:55 AM
WALFORD'S 56
13
Jul 22, 2010 11:20 AM
Kijutsu
1983 - 2012 Ranger & B-Series
Feb 27, 2009 07:19 AM
4x4bigblock
Electrical Systems/Wiring
13
Feb 24, 2006 08:30 AM
77fromheaven
Apr 2, 2003 02:21 AM
