sync issues
Old Jan 1, 2014 | 03:39 PM
derek4343's Avatar
derek4343
sync issues
does anyone who has the sync feature have issues with it understanding you or playing what you want it to play? i have 2009
Old Jan 1, 2014 | 04:08 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
mine works most of the time, but intermittently the voice commands will fail to find a song I know is on my USB drive, but I can see clearly on the menu. It is really bad if you have the fan on high or the sunroof open...distorts the voice.
Generally speaking, it is better than not having any sync, but the technology is poor and was probably released too early with insufficient testing.
Old Jan 2, 2014 | 10:44 AM
FordIVTteam's Avatar
FordIVTteam
Official Ford Rep
Hi derek4343,
I can help you with this. Which kind of device are you using to play your music, USB thumbdrive or MP3 player? Big-Red-Lariat is correct about using your blowers and A/C, which can increase microphone distortion inside the cab. Try adjusting your climate controls to see if this might be a factor.
Antonio
Old Jan 2, 2014 | 01:17 PM
Big-Red-Lariat
Today I loaded an album by Al Stewart, then I say "Play Artist Al Stewart", and it plays Rod Stewart...does Al really sound like Rod? Bottom line is it has at least half a brain.
Old Jan 3, 2014 | 07:18 AM
ubereal2's Avatar
ubereal2
I've had a few issues with my Sync also. There have been several times where I can't even get the phone and Sync to connect (With Bluetooth). But it seems to work better if I have the truck running for several minutes (Like letting a computer boot up) before I even try. And I have had times where Sycn just doesn't seam to understand me. I don't even try with the windows down, of fan motor blowing hard.
Unk Bob
Old Jan 3, 2014 | 10:37 AM
QwkTrip's Avatar
QwkTrip
Yes, command recognition can be very annoying at times. I've found a handful of key words and commands it understands consistently and I don't venture much beyond that any more. Half the time I have to dial directly from my phone instead of SYNC.
Lately I've had problem with the phone not connecting while I drive. I frequently have to manually connect bluetooth because it is not happening automatically. A few times I've had USB randomly disconnect from iPod while playing music. All told, I have fewer problems than many people.
Old Jan 3, 2014 | 02:23 PM
FordIVTteam
Official Ford Rep
Originally Posted by ubereal2
I've had a few issues with my Sync also. There have been several times where I can't even get the phone and Sync to connect (With Bluetooth). But it seems to work better if I have the truck running for several minutes (Like letting a computer boot up) before I even try. And I have had times where Sycn just doesn't seam to understand me. ...
Hi ubereal2,
If the connection lag seems to get worse, try performing a clean pairing:
Hello QwkTrip,
Have you tried soft resetting your phone? Sometimes the Bluetooth signal from your chip can degrade in strength over time. A soft reset can be performed by removing the battery for about three minutes, then reconnecting with SYNC. A clean pairing, as I've suggested above, can also improve your overall Bluetooth connection and voice recognition accuracy (via the master reset).
Antonio
Old Jan 3, 2014 | 03:28 PM
QwkTrip's Avatar
QwkTrip
Thanks for the hints. I have a habit of removing battery from phone occasionally because it seems to increase battery life. I guess I've been unintentionally doing soft resets as well. I've never done a master reset of SYNC. I will try that.
What do you think could be causing the iPod to suddenly not be recognized by the USB port? For example, I will be driving down the road listening to music for the last several hours and all of a sudden SYNC doesn't think anything is connected to USB. In best case scenario I have to reboot the iPod and it works again. In worst scenario it won't work until after truck key switch is cycled off and on again. I use the same iPod in a docking station with the home stereo and it has never unintentionally disconnected.
Old Jan 3, 2014 | 08:58 PM
DBLX's Avatar
DBLX
My 2009 works like a champ. Only complaint would be the microphone... Some say they can barely hear me.
Old Jan 4, 2014 | 12:39 PM
derek4343's Avatar
derek4343
Thanks everyone. It was me mostly not giving the right command at first. Has anyone updated theirs from home on the computer by thumb drive
Old Jan 5, 2014 | 09:02 AM
ubereal2's Avatar
ubereal2
I had to learn how to give the correct command too. And still learning.
I tried the download to a thumb drive and do the update myself. But I'm not much of a computer person, and it is working. So I guess I'll leave it alone.
Unk Bob
Don Vito
15
Apr 23, 2016 08:03 AM
bballcrf
51
Jan 23, 2015 03:13 PM
ChunderDownUnder
16
Nov 14, 2010 02:24 AM
nmaranto
Mar 7, 2010 07:35 PM
rcav8or
Jun 6, 2008 06:45 AM
