f-250 VIN decode please
Old Jun 25, 2003 | 09:39 PM
Burnsides's Avatar
Burnsides
Question f-250 VIN decode please
I just got this truck from my boss, I am pretty sure it is a '72 but I found some decrepencies, and would like to know what the VIN decode for this truck is, thanks
Vin F2BPC84364
WB COLOR MODEL BODY TRANS AXLE
131 J F253 4 81 F 38
GVW CERTIFIED HP RPM DSO
6100 139 3600 44
the truck has a V-8 in it but from what I did find I am not sure if it original (according to what I found the original was a 6) thanks again. Ryan
Old Jun 25, 2003 | 11:17 PM
Mil1ion's Avatar
Mil1ion
F25 = F250 Pickup
B = Engine = 300 I-6
C = plant of build = Ontario Truck
84364 consecutive build number (There is Missing letter or if the C is right that would make it an 69.)
WB 131 = 131"
COLOR = J = Rangoon Red ?
MODEL = F253 = GVW Code = 7900 lb
BODY = 4 = Medium Beige Vinyl
81 = Conventional cab
TRANS = F = 4 spd Warner T-15
AXLE = 38 = Dana 60 - 3.73:1
GVW 6100lbs
CERTIFIED HP = 139 HP RPM
3600 at 3600 Rpm
DSO 44 = Twin Cities
Old Jun 26, 2003 | 12:25 AM
Burnsides's Avatar
Burnsides
oops sorry f25bpc84364, is what I have written down, I can't check it until tomorrow to confirm its correctness.
the engine in it is a V-8 but I am pretty sure that it was swapped since the carb has an ID tag D4DE, which as far as I know decodes to 74 falcon engine.
Old Jun 26, 2003 | 12:36 AM
Mil1ion's Avatar
Mil1ion
My previous post has been edited.
Are you sure that D isn't an O?
Old Jun 26, 2003 | 01:10 AM
Burnsides's Avatar
Burnsides
almost completely positive on the carb code, the tag on it was clean and easy to read.
the full carb ID tag was
Motorcraft
D4DE LA
A 3G 26
the warranty # would have put the assembly plant in the twin cities, instead of ont. right?
BTW thanks for the info
Old Jun 26, 2003 | 01:17 AM
Mil1ion's Avatar
Mil1ion
Yes, DSO 44, is the Twin Cities
