ultimate goof
Old 12-29-2013, 02:09 PM
newguy399's Avatar
newguy399
newguy399 is offline
ultimate goof
Hey guys made a ugly bubo. Was changing the outer bearing cup in the rotor from speedway and,put the new one in backwards and before I realized it was to late.what are my options now.
Old 12-29-2013, 02:26 PM
dmack91's Avatar
dmack91
dmack91 is offline
You should be able to turn it over and punch it out with a long flat-faced punch. There should be enough of an edge to catch the punch. Just make small hits as you work your way around, hitting it on opposite sides. Knock any burrs off and put it back in the correct way.
I can think of a lot of more serious mistakes that I have made. None unsurvivable.
Old 12-29-2013, 02:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
You "might" be able to slip the cone in from the other side and press the race out. It still may dent the race surfaces tho.
Old 12-29-2013, 03:07 PM
yamagrant's Avatar
yamagrant
yamagrant is offline
Are you talking about the bearing adapter that fits on the spindle? If so heat it up with a propne torch and wedge a chisel between the adaptor and slindle body. It should come off easy. then re install it. Good luck.
Old 12-29-2013, 04:07 PM
toby tough's Avatar
toby tough
toby tough is offline
Maybe you can find a big socket that would match the circumference.Wqw, that was a big word for me. Tap it out nice and easy.
Old 12-29-2013, 06:42 PM
newguy399's Avatar
newguy399
Thanks guys its not the adaptater that goes on the spindle,its on the rotor, I will try those tips thanks guys
Old 12-29-2013, 07:17 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
If those ideas don't work on your reverse installed cup , and I suspect that there won't be any edge presenting itself to drive against . You can take a cold chisel and create some exposure against which to use a punch .
Old 12-29-2013, 07:23 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
And by the way i've pulled off way worse than that i'm proud to say . One occasion that comes to mind was welding my truck inside a steel rail corral .
Old 12-29-2013, 07:39 PM
Olweldinrig's Avatar
Olweldinrig
Olweldinrig is offline
Not me but a favorite of mine.A friend in highschool changed a quarter panel on his 71 chevelle.Meanwhile they stored the mint back bumper in the trunk.
Guess what had to be cut in half to remove!
Old 12-29-2013, 07:51 PM
newguy399's Avatar
newguy399
That makes me feel better thanks for all the help
Old 12-29-2013, 07:53 PM
Olweldinrig
That was 20 yrs ago and still gets brought up once in a while.A true classic goof!
Old 12-29-2013, 10:16 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
Yeah no one reminds you of your brilliant accomplishments any to often .
Old 12-29-2013, 10:40 PM
newguy399's Avatar
newguy399
Just got the cup out without damage,1-1/8 socket and a big f**king hamer
thanks again guys
Old 12-30-2013, 01:32 AM
nassi's Avatar
nassi
nassi is offline
It would have been pricless to see your face when you realised.
BroncoBilt
1978 - 1996 Big Bronco
12-23-2014 08:00 PM
99whitef150
1997 - 2003 F150
01-15-2011 03:58 PM
effie_man
54
10-05-2007 01:00 AM
cigarxtc
Garage & Workshop
05-21-2004 08:24 AM
Dog_Driver
05-04-2004 02:27 AM
Quick Reply: ultimate goof
