man.leak or valve ping??
Old Jun 25, 2003 | 07:28 PM
longview1's Avatar
longview1
Banned
The title is pretty much my question.
Basicaly its like this: Its a 360 by the way with stock manifolds(only for another week tho), and everything else for that matter.
So, After about 5 mins of driving, there becomes a frapping sound from inside cab, doesnt really speed up as I gas it, but when I pop the hood and listen, it sounds like a/the valves hitting the valve cover, kind of sounds like manifold leak too. Im not familiar with the sounds of either so I cant distinguish which is which, any help or info would be great, and much appreciated. A friend said it was manifold leak (his dads truck doing same thing he said) and now its coming from both sides.
And yeah, I am noticing some weak power.
Im getting some Hedman headers next week whether its manifolds or not but, it would be nice to know, it sounds like crud.
Thanks for the good word *cheers*
Old Jun 25, 2003 | 07:35 PM
clods64fe's Avatar
clods64fe
I would suggest pulling one valve cover (since it's coming from both sides) and taking a look. It could possibly be exhaust leaks also. However if your noticing power loss I would venture a gues at the valve train. Use a long piece of hose when it is doing it and locate, as close as you can, where the sound is actually coming from.
Old Jun 25, 2003 | 07:40 PM
longview1's Avatar
longview1
Banned
hey that was quik,.. thanks man
Um..yeah I will go and try takinfg off pass. side cover, thats where it started, and I tried taking off the driver side a couple months ago and couldnt get it off....I didnt want to pry it off either, but Its not like i tried for an hour or more.
Old Jun 25, 2003 | 08:07 PM
clods64fe's Avatar
clods64fe
pop thet valve cover with a rubber mallet kinda littly around the parimeter and it should come off.
Old Jun 26, 2003 | 09:59 PM
longview1's Avatar
longview1
Banned
I got the pass. side cover off, was quite easy, popped of with my fingers, anyway, i listened to it and it is the valves making the noise. which ones exactly I sure dont know.
I found a 429cj somewhere close and he wants roughly 1,000 canadian. Im thinkin I should get a grand and go pick er up.
