Air Injection pipe question
Old Dec 29, 2013 | 09:04 AM
NW 150's Avatar
NW 150
I have a 96 f150 with the 300 that has one of those air injection pipes that run along the top of the head and screw in to each cylinder. My question is what is the size/ thread specs for those ports? I want to get a tap to clean them up because I'm having trouble getting two of them to seal, which is causing a vacuum leak and it's throwing codes.
Old Dec 29, 2013 | 03:25 PM
6978sghfbjklgdfsjhkl's Avatar
Hi There..
I was hoping others here would chime in, it seems I've been WAY to active here for the last few days...Anyway..
FORDSIX PERFORMANCE • View topic - EFI Smog Injection Plug Size
This thread on another site will help you and give good reading as well..
It seems that the general consensus is 9/16x18 or "fine thread. VERY close to a 14mm spark plug. I have a head off and in my shop. I don't have a fine 9/16" tap to verify..Something I should get I suppose, I like to use these heads...and I have not been able to get those fittings off w/o "help" in the past..chasing threads would certainly be good for the NEXT time you have to get it off...
Best wishes
Old Dec 30, 2013 | 10:32 AM
NW 150's Avatar
NW 150
Alright cool thanks for the info!
Old Dec 30, 2013 | 04:41 PM
bill06447's Avatar
bill06447
Kroil to get 'em out...NeverSeize to put 'em back ~Bill
Winter3531
Apr 30, 2020 02:39 PM
Colorado Ford Guy
Apr 12, 2012 06:25 AM
Diesel_Aggie
Mar 6, 2011 12:21 AM
pdsq89f150
Feb 9, 2004 12:13 PM
racesidner
Nov 12, 2003 10:27 PM
