adding fuse block what wire size ?
Old Dec 29, 2013 | 06:39 PM
skyway0018746's Avatar
skyway0018746
Finally two people who know what they are talking about. I saw the painless one but the price is outrageous. Im thinking about relocating it to under the hood.
I have a spare fuse block from a jeep I might use or may order a custom / modular one.
When people say I can't it just makes me want to do it more.
Old Dec 29, 2013 | 07:19 PM
devino246's Avatar
devino246
I don't doubt that you can, but it's alarming that you were unaware that different circuits use different gauge wires. That little bit of information could be the difference in your project working perfect, or your truck catching fire.
Old Dec 29, 2013 | 07:21 PM
skyway0018746
I am aware that bases on amp draw and length of run it will be different. I was a little tired last night .
Old Dec 29, 2013 | 07:26 PM
devino246's Avatar
devino246
I feel that. Good luck with your project
Old Dec 29, 2013 | 08:18 PM
psychlopath's Avatar
psychlopath
...who know what they are talking about....
Yep, those were the only people here who knew that there were different sized conductors for various loads in a vehicle.
No one said you couldnt do this; Good luck with it!
I won't be posting how it turns out
You showed us! All of us.
Old Dec 29, 2013 | 08:30 PM
skyway0018746
Thanks for all your help, I ordered #4 wire just to be safe
Old Dec 29, 2013 | 09:20 PM
Dave145's Avatar
Dave145
When I redo any kind of wiring in older vehicles I like to increase the wire gauge by one. Meaning if a circuit uses say 22 gauge wire, I like to step it up to 20 gauge just to be on the ultimate safe side.
Old Dec 29, 2013 | 09:28 PM
HIO Silver's Avatar
HIO Silver
Non-Sequiter
Well, the thread title is to add a fuse block, not to replace it. Then in yer first post you stated "switching over the blade fuses".
I suggest perusing the JY for an OEM underhood load center like from a Taurus or yes, Jeep. ...Low-buck, adaptable, and usually weather sealed. plus they come with a Megafuse, relays, and such.
Old Dec 29, 2013 | 09:34 PM
skyway0018746
Ah I can see how that can get confused. Yes I am replacing the factory fuse block. I opted for a painless block just couldn't find what I liked here in the u.s.a. everything is overseas.
Old Dec 29, 2013 | 09:43 PM
HIO Silver's Avatar
HIO Silver
Centech has a fuse block for $125. PDP-1B High Tech Fuse Panel
They even have complete wiring systems if that's on the horizon: Early Ford Broncos & Trucks
Old Dec 29, 2013 | 09:47 PM
skyway0018746
That harness has a better price then painless. Ill keep it in mind if the factory stuff starts going south.
Old Dec 30, 2013 | 11:02 AM
Jim Lenna's Avatar
Jim Lenna
I think #4 is gonna be too large of diameter in there behind a fuse panel to bend around the corner out thru the grommet. Even for splicing it will be hard to find connectors to go from #4 to your existing wiring. Also, I try to match colors as best as I can so if there is a problem in the future...
Not trying to **** on your parade!
Tilleyman
Feb 24, 2016 01:05 PM
Golden210
Nov 10, 2014 08:14 AM
sflem849
59
Apr 2, 2008 03:07 PM
