Drag link question, 1956 F100
Old 12-27-2013, 06:34 PM
seawulff's Avatar
seawulff
seawulff is offline
My steering has always been rough, kind of sticks and binds. I bought a spring scale and adjusted the steering as per the manual and with the pitman arm loose it is smooth and appears appropriate. I disconnected the drag link and when I took the end off there is no spring or other pieces in there just the two pieces that surround the ball on the pitman arm. Is this correct? The manual shows a spring, and spring guide plus the other parts. Is this the reason it is rough? Thanks.
Old 12-27-2013, 07:45 PM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
I would suspect the steering could be quite rough, sticky without the ***** being under spring pressure and the cushion and flexibility the springs provide. Check the ***** for being round, replace if worn. Order and install a rebuild kit correctly.
Old 12-27-2013, 10:29 PM
artford54's Avatar
artford54
artford54 is offline
What's the best way to change the ball stud? Take the arm off? Help!
Old 12-27-2013, 11:55 PM
seawulff's Avatar
seawulff
seawulff is offline
Thanks, already ordered!
Old 12-28-2013, 12:39 AM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
The worm gear in the box is also know to chip and give some strange feelings.
Old 12-28-2013, 02:11 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
A8TZ-3A533-A .. Draglink Ball Stud Repair Kit-1948/52 F1/F2/F3 / 1953/56 F100/250.
Note in pic that basic numbers with black dot are included in kit.
Left upper picture:
Old 12-28-2013, 10:54 PM
artford54's Avatar
artford54
Sorry for getting my nose in there. Ignore my question.
19fifty4
16
12-14-2015 06:00 AM
swazi212
1999 to 2016 Super Duty
01-04-2012 08:41 PM
Campbell 56
04-26-2006 07:37 PM
HighProCam
15
06-22-2005 04:42 PM
tp
09-19-2003 06:36 PM
Quick Reply: Drag link question, 1956 F100
