Does anyone sell a full drum rebuild kit?
I'm considering picking up a 67 from a guy across town to do a little maintenance work on and turn into a daily driver. He drove it up and down his street when he got it and said it runs fine but the rear brakes want to drag a little when you press the brakes so he didn't recommend driving it home.
I have limited knowledge on drum brakes, as I come from the turbo import world. I was just curious if anyone knew of a vendor who sold a complete kit to do the whole truck? Drums, pads, wheel cylinders, any springs/bolts/etc I might need. I'm sure the Auto Zone up the road has everything in stock I need but don't really want to make 5 or 6 trips when it's about 20 miles round trip each time.
Ford Racing Performance Parts (frpp AKA Ford Motorsports) used to carry a kit that came with both rear loaded backing plates with brakes. No drums. Part number was M2209B. 11 X 2 1/4" brakes for a F100. Had 3.150 center pilot hole. .381 attaching bolt holes. 3.56" x 2" attaching bolt pattern. These dimensions may be different on a 1967. If you want this kit call Beasley Ford. 717-755-2911 ext 1278.
It is a F100,correct? If so I'd double check the measurments I posted above compared to your 1967 before purchasing.
94_9high_250
11-19-2005 05:43 PM
mechanicsburg
11-09-2004 05:33 AM
