Cold start problems
Old Dec 27, 2013 | 03:58 PM
Hokiewheeler's Avatar
Hokiewheeler
Cold start problems
Hey gang. I've read some of the other cold start issues and I've been doing some research. When it gets below 20 out, the truck is a real bear to start. It's like trying to start an old Detroit. I was thinking glow plugs were bad, but I'm not so sure now. It blows a lot of black smoke on start up. I'm thinking I may have a stuck injector. I changed fuel filters recently and that had no effect. They were about 6k mi past due. After about 5 minutes warming up, it's alright, and now that it's been warmer out, it starts up ok. Over 40, no problem. I've had this truck 3 years and it's always been alright even really cold. Now it won't even make power til you warm it up for 5 or 10 minutes. What are your thoughts, and how can I check for bad injectors? I may have to have it diagnosed. The truck wasn't optioned with a block heater by the original owner...
Old Dec 27, 2013 | 04:05 PM
Banage's Avatar
Banage
Many other threads say All 6.0 have a heater. Some just didn't come with the plug.
Old Dec 27, 2013 | 04:16 PM
Hokiewheeler
I have heard that too, where would I look for the hookup?
Old Dec 27, 2013 | 07:45 PM
Forddiesel06's Avatar
Forddiesel06
Hokiewheeler look on passenger side just above the the starter and u should see the blocker heater, now they may or may not come with the pig tail. You can get one thru amazon for less then the dealer price. Also if u have a full connection go to the front of the truck near hooks and u might see it.
Old Dec 27, 2013 | 08:09 PM
CPB1's Avatar
CPB1
What are your FICM Volts?
Old Dec 28, 2013 | 08:19 PM
Hokiewheeler
Haven't checked the FICM. Is it possible to check the voltage on it without a diagnostic tool?
Old Dec 28, 2013 | 08:25 PM
CPB1's Avatar
CPB1
I have never done it but it is possible. The procedure is in the tech folder. You need a DVM. and an assistant.
Old Dec 28, 2013 | 09:48 PM
Hokiewheeler
If I get to it tomorrow I will post up some results. I may go pick up one of those scan gauges.
Old Jan 17, 2014 | 02:07 PM
Hokiewheeler
I don't have a block heater on the truck at all. I got a 1500w space heater that I was setting on the front diff by the oil pan to get it to start. At any rate, I finally took it in to the shop. Bad FICM - they got me for 1200 bucks for the job, new part was 788 with a 200 core. They f'd me on the part from what I can see, Ford wants 598 for a programmed one.
captfatboyf250
Jul 8, 2015 11:32 PM
mikekline316
Oct 12, 2014 08:35 PM
cbenz73
Feb 14, 2014 10:07 PM
Pheadrus
Jan 3, 2014 05:01 PM
c-bolt
Feb 13, 2008 06:01 PM
