waterless coolant?
Old Dec 28, 2013 | 08:57 AM
helifixer's Avatar
helifixer
looks very interesting
Old Dec 28, 2013 | 09:05 AM
diehardstroker's Avatar
diehardstroker
It sounds like a great product that actually works like it says. Ill definitely be considering this when I do my coolant flush. Would it be a good idea to add a coolant filter to the system?
Old Dec 28, 2013 | 10:05 AM
Pikachu's Avatar
Pikachu
The MSDS for it shows it to be 66-70 percent ethylene glycol which is the primary ingredient in green coolant, less than 2 percent "proprietary corrosion inhibitor package", and the remainder to be propylene glycol (the pink stuff for winterizing pipes) and water.
Old Dec 28, 2013 | 10:10 AM
diehardstroker
is that a bad thing or a good thing? Im still trying to learn what chemicals in what are good or bad lol
Old Dec 28, 2013 | 10:14 AM
Pikachu's Avatar
Pikachu
I don't think it's necessarily good or bad, but it sounds expensive for what it is. Another thought that comes to mind, and I could be completely wrong about this, is it seems a zero pressure system would be more susceptible to hydrodynamic or ultrasonic cavitation in the water jacket around the cylinder walls.
Old Dec 28, 2013 | 10:17 AM
mueckster's Avatar
mueckster
IIRC, Barney it still running a coolant filter with the Evans coolant. I remember his changing the filter when he was at my house a few years ago for a wrenching session of his truck.
Old Dec 28, 2013 | 10:37 AM
mueckster's Avatar
mueckster
Did you read this entire article (all the way to the bottom) on Dieselsite? http://www.dieselsite.com/evansnpgnp...uantities.aspx It explains its benefits and how it reduces/eliminates those problems.
I would probably be running the stuff if my truck didn't eat water pumps. On the fourth one now since the original.
Old Dec 28, 2013 | 10:44 AM
diehardstroker
dieselsite is the only place i could find a coolant filtration system and it looks well put together, but are there any other places that make a complete system?
Old Dec 28, 2013 | 10:54 AM
mueckster's Avatar
mueckster
Clay sells the coolant filter system made by Sinister Diesel. Sinister Coolant Filtration System / Filter Kit 99-03 - Riffraff Diesel Performance
Old Dec 28, 2013 | 10:58 AM
Pikachu's Avatar
Pikachu
I did read it, but it sounds like the cavitation it refers to is that caused by the boiling of the water component in the coolant. It doesn't specifically mention hydrodynamic or ultrasonic cavitation anywhere. Like I said, I could be completely wrong about it, but I felt it was worth mentioning as a possibility. I do have a tendency to over think things but that's part of being a compulsive perfectionist, I guess . . .
Old Dec 28, 2013 | 11:04 AM
diehardstroker
i must not have found it with their new website, cause i did look there. thanks for the link.
Old Dec 28, 2013 | 11:07 AM
diehardstroker
thats a good point though. im sure somebody on here will know but will they see the thread lol
Old Dec 28, 2013 | 11:18 AM
  #28
mueckster's Avatar
mueckster
I used the "search" box to find it.
jed1894
29
Oct 15, 2022 01:25 PM
jetedwards
Nov 2, 2020 12:25 PM
superduty91
6.7L Power Stroke Diesel
18
Jul 1, 2015 09:50 AM
96 Power Stroked
Jan 11, 2006 06:36 PM
SpringerPop
Oct 14, 2005 04:45 PM
