I run between 60-80 psi from empty to carrying 4500lb camper,some will recomend going with fords air press chart printed on door jam or some take & smear chalk or grease pencil on tread & drive & observe wear pattern, if it wears off outer first then under inflated.if wears in center first its over inflated.
I apologize for inserting a bit "off topic" reply but I need an answer.
Are there any Ford 16" Steel Wheels, 5 lug made for my F150?
I will paint them so I do not want alloy wheels.
Thank you!
Boon
P.S. I like the chalk idea and now another tool for the memory banks!
Wrong section, but You have hundreds of choices of 5 on 5.5 steel wheels. I can't think of factory ford in this size, but there are many others that work.
