Electircal problems???
Old Dec 26, 2013 | 10:12 AM
Kingkoopa's Avatar
Kingkoopa
So i went the start my 95 powerstroke this morning and heard a loud pop and not both of my brand new batteries are dead. ihave tried recharging them and my check engine light is now on and the WTS light is not coming on. any ideas guys i am really lost on this one?
Old Dec 26, 2013 | 10:57 AM
redman84's Avatar
redman84
Check fuse 22 under the hood. Are the batteries dead from trying to crank or what?
Old Dec 26, 2013 | 10:59 AM
Kingkoopa's Avatar
Kingkoopa
They just died when I heard the pop.
Old Dec 26, 2013 | 05:31 PM
Kingkoopa's Avatar
Kingkoopa
I'm putting a video on YouTube of what is going on search 95 f350 7.3 no start
Old Dec 26, 2013 | 10:35 PM
oldbird1965's Avatar
oldbird1965
A bad battery will draw a good one down.
Old Dec 27, 2013 | 09:33 AM
Hussler's Avatar
Hussler
Looked at your YouTube video and the door ding'r is working so you have some power. A loud pop is almost always an electrical connection. Can you give more information? Did the truck engine turn over at all when this happened? Do the headlight work? I would start by looking at the starter connections because everything else is fused and should protect itself. Do you have a volt meter to do some basic troubleshooting?
Old Dec 27, 2013 | 09:53 AM
Kingkoopa's Avatar
Kingkoopa
When it happened there was no cranking at all the moment I turned the key is when I heard the pop. I'll get a volt meter from harbor frieght
Old Jan 14, 2014 | 07:05 PM
Kingkoopa's Avatar
Kingkoopa
So I'm still having problems. I'll put the video on you tube. For now this is the problem both batteries are fully charged and the engine light is on and it makes a loud ticking noise and it makes a thud when you turn the key. The video will be titled (electrical problems with 7.3)
Old Jan 14, 2014 | 08:28 PM
madpogue's Avatar
madpogue
Post a link.
Does it make the thud when you turn the key to RUN, or when you turn the key to START?
Old Jan 14, 2014 | 08:46 PM
Kingkoopa's Avatar
Kingkoopa
Old Jan 14, 2014 | 08:59 PM
madpogue's Avatar
madpogue
LOAD test BOTH batteries, in isolation from one another. Also check main battery positive and ground connections.
The indicator on that charger doesn't tell you much when both batteries are connected. Try this - disconnect the negative on the driver's side battery, put that charger on the passenger side and see what it says. Also try turning the key to RUN (NOT TO START), and see if you get the WTS light and no clicking. If that doesn't help, try reconnecting the driver's side negative and disconnect the passenger side negative, and try the same thing.
The idea is to see if at least you can power up the PCM and the accessory electrical system on either battery by itself. If it _does_ act "normally" with just one battery connected, the _other_ battery is faulty. If that's what you find out, then charge JUST that battery with your charger. If it takes, and HOLDS, a charge, you're probably out of the woods. If not, and if both batteries are about the same age, then your best bet is to replace both.
havdan85
Jun 20, 2015 10:29 AM
laraby
21
Sep 27, 2013 01:08 PM
sola forda
44
Mar 6, 2013 05:03 PM
bobbyt89
Jul 30, 2011 09:43 AM
96_7.3_Dually
Jun 26, 2011 11:26 AM
