Need help ID ing a 3-speed. Currently its in a 53 F-100 but I'm not sure its the correct year. When I got the truck i found out the engine had been swapped to a 223 instead of the 215 it should have came with. So I am wondering if the trans was swapped too. The casting on top of the case is 1A-7006-A. I dont have a bolt on tag or a VIN plate. Thanks for any help.
Column shift or floor shift? Top-loaded or side-loaded? Can you post a picture? From the casting number I'd guess it's a plain old stock 3-sp, and there aren't many differences from '53 - '57 or so.
1A-7006-A is the number for the trans case only, it's not the trans ID number.
7006: As you can see (listed first), this case was used in 1951/54 Ford Passenger Cars with 3 M/T.
Resurrecting my three year old post here...Looking for a slip yoke for the 3 speed above that was not original to the truck. 16 spline, three speed on the column in a 53 F-100. Evidently the trans was original to a Ford car. I can post HUGE pics now lol.
Scroll down to 4841 .. slip yoke basic part number, specs listed first, then the part number below.
1949/56 Ford Passenger Car (A) & 1955 Thunderbird (S): B5A-4841-A
But, no Ford dealer or obsolete parts vendor has B5A-4841-A or B5A-4841-B or B5C-4841-A
I did find one that should work. It's not listed in this car parts catalog, but after you respond to this post, I'll post a pic, part number and sources that have it.
Ross, I checked my Spicer driveline parts catalog and the 2-3-1331X slip yoke you listed is the only one in the catalog for that spline diameter and number.
Mark
Sorry, I should have been clearer. My parts books list driveline parts by dimension, not application. I checked my parts books to see if there was another option. There are usually different lengths available with the same spline and u-joint series. But, the yoke you listed is the only yoke with that spline, so this looks like the only new part available to him for his transmission.
Mark
