Different generation bed swap
Old Dec 23, 2013 | 09:11 PM
Briarcreekrat's Avatar
Briarcreekrat
Does anyone know if pre 80 - 86 stepside beds will bolt up to our gen trucks as in 1975 flare side onto 1984 both short box? Will it bolt right up ?
Old Dec 23, 2013 | 09:25 PM
ctubutis's Avatar
ctubutis
No, it won't; differing widths.
Old Dec 23, 2013 | 09:35 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Front half of frame is narrower, but I believe the rear half is the same width. The wide beds use the same floor from 73-96, though the rest of the sheet metal is different.
I have seen older beds on newer trucks, and newer beds on older trucks. I doubt some them would have bothered doing it if it wasn't a pretty easy swap......
Old Dec 23, 2013 | 09:40 PM
ctubutis's Avatar
ctubutis
Sure, anything can be done with some work... but, he explicitly asked - "Will it bolt right up?"
Old Dec 23, 2013 | 10:03 PM
Rogue_Wulff
73-79 pickups, not counting "highboys" and cab/chassis trucks have a rear frame width of 37". Isn't that the same as 80-96?
Yes, the front half is only 34", but it widens between the cab and bed.
The trucks listed as exceptions, have 34" width front to rear.
Old Dec 24, 2013 | 03:27 PM
Briarcreekrat
Thanks for the help , I wonder if anyone has any pics of said bed swap.
Old Dec 24, 2013 | 03:44 PM
Franklin2's Avatar
Franklin2
I am sure it would not look very good. With a 87-up swap at least 90% of the body lines match, all except the curve over the rear wheel. 79 down would not match at all. Unless it was a stepside bed(that chevy's version, I can't remember what Ford called it.
Old Dec 24, 2013 | 05:33 PM
Diesel_Brad's Avatar
Diesel_Brad
80+ Ford frame widths are 36"
And listings for the crosmembers are the same from 73-87 so I will say YES, it will bolt right on
Old Jan 3, 2014 | 09:26 PM
Briarcreekrat
Talking
Yes as mentioned in original post stepside.....flare side bed, so body lines matching up or looking good is not an issue . I just want the old stepside look with metal fenders instead of fiberglass . I will report back with some pics soon , Thanks again for everyone's input .
Old Jan 4, 2014 | 07:32 AM
Diesel_Brad
What is wrong with the fiberglass fenders. All least they don't rot out
Bryan Tremmel
Jul 6, 2017 01:27 PM
Rasputin53
May 26, 2014 11:48 PM
mwc2010
Aug 8, 2011 09:28 PM
reamer
Jul 16, 2011 10:20 PM
Gman91
Feb 7, 2008 07:46 PM
