how much coolant in prim/second
Old Dec 21, 2013 | 06:16 PM
macguy's Avatar
macguy
Our 6.7 motors take 9 gallons antifreeze 50/50. How much of it is used in primary and secondary?
Old Dec 21, 2013 | 06:58 PM
F stock owner's Avatar
F stock owner
My manual says 41.8 quarts (10.45 gallons). Per manual, be sure to use distilled water.
SECTION 303-03B: Engine Cooling — 6.7L Diesel Powertrain Primary Cooling 2012 F-250, 350, 450, 550 Super Duty Workshop Manual
SPECIFICATIONS Procedure revision date: 07/20/2011
Material
Item / Specification / Fill Capacity
Motorcraft® Engine Cooling System Iron Cleaner VC-9 / — / —
Motorcraft® Orange Antifreeze/Coolant Concentrated VC-3-B (US); CVC-3-B2 (Canada) / WSS-M97B44-D / 27.8L (29.4 qt)
Motorcraft® Specialty Orange Engine Coolant Revitalizer VC-12 / — / —
General Specifications
Pressure Tests
Complete cooling system maximum pressure Use individual reading listed on the pressure relief cap
Pressure relief cap Use individual readings listed on the pressure relief cap
Radiator (out of vehicle) 138 kPa (20 psi)
Thermostat Opening Temperatures
Starts to open — (low temperature) 88-92°C (190-198°F)
Fully open — (low temperature) 100°C (212°F)
Starts to open — (high temperature) 92-95°C (198-203°F)
Fully open — (high temperature) 103°C (217°F)
Torque Specifications
Description Nm / lb-ft / lb-in
A/C tube fitting nuts 15 — 133
Battery cable bracket bolts 12 — 106
Block heater 41 30 —
Charge Air Cooler (CAC) bolts 12 — 106
Coolant crossover manifold bolts 10 — 89
Coolant outlet connection bolts 10 — 89
Coolant pump bolts - large bolts 24 18 —
Coolant pump bolts - small bolts 10 — 89
Cooling fan-to-cooling fan clutch nuts 7 — 62
Cooling fan clutch 133 98 —
Cooling fan clutch electrical connector bracket bolt 24 18 —
Cooling fan shroud bolts 7 — 62
Cooling fan stator nuts 17 — 150
Cylinder block drain plug 60 44 —
Degas bottle bolts 19 — 168
Engine wiring harness-to-coolant crossover bolt 10 — 89
Fuel tube bracket bolts 10 — 89
Grille bracket bolts - lower 3 — 27
Grille bracket bolts - upper 40 30 —
Heater inlet tube bolts 10 — 89
Power steering fluid cooler bolts 35 26 —
Power steering fluid reservoir bolt 7 — 62
Power steering pressure hose bracket screw 5 — 44
Radiator bracket bolts 35 26 —
Radiator bolster bolts 40 30 —
Secondary degas bottle bolts 7 — 62
Secondary radiator bolts 11 — 97
SECTION 303-03C: Engine Cooling — 6.7L Diesel Powertrain Secondary Cooling 2012 F-250, 350, 450, 550 Super Duty Workshop Manual
Material
Motorcraft® Orange Antifreeze/Coolant Concentrated VC-3-B (US); CVC-3-B2 (Canada) / WSS-M97B44-D / 11.7 L (12.4 qt)
Item Specification
Pressure Tests
Complete cooling system maximum pressure 172 kPa (25 psi)
Starts to open — low temperature 20°C (68°F)
Fully open — low temperature 30°C (86°F)
Starts to open — high temperature 45°C (113°F)
Fully open — high temperature 55°C (131°F)
Description / Nm / lb-ft / lb-in
A/C condenser bolts 11 — 97
Accessory drive belt tensioner bolt 48 35 —
Coolant pump bolts 25 18 —
Cooling fan stator standoffs 22 16 —
Degas bottle bolts 7 — 62
Radiator bolts 11 — 97
Thermostat cover bolts 6 — 53
Old Dec 21, 2013 | 08:30 PM
macguy's Avatar
macguy
Does drain **** bottom left hold both amounts?
Old Dec 22, 2013 | 04:40 AM
djousma's Avatar
djousma
No, that is primary only. On the right side, there is another drain **** for the secondary.
Old Nov 9, 2014 | 05:15 PM
BrodyUSMC's Avatar
BrodyUSMC
So did I read that right 27 quarts in the primary and 12 in the secondary? My radiator is leaking and I am just going to replace it but I want to have enough coolant on hand once i do it and its 1899 a gallon so I want to have enough here? Could someone clairify that for me please?
Old Nov 9, 2014 | 05:46 PM
senix's Avatar
senix
The owners manual will have the correct amount.
I have not looked it up but that is where I would go to for common replacement fluids and capacity.
Old Nov 9, 2014 | 05:51 PM
BrodyUSMC's Avatar
BrodyUSMC
yea I thought so too it says 29Q bt its not broken down between primary and secondary
Old Nov 9, 2014 | 05:55 PM
senix's Avatar
senix
Oh, I see. I think you will have to break open the secondary at any rate to change the radiator out.
I think they only thing you can away without touching is the A/C condenser and the other 1/2 dz radiators.
Do some searching on youtube. You maybe able to find a video of the procedure and I'll bet that will give you some hints.
Adrenalin540
Feb 12, 2015 07:52 PM
rblaine9000
Dec 13, 2010 01:42 PM
Stewart_H
Dec 4, 2010 07:02 AM
Dannym
Dec 17, 2004 07:25 AM
wickware
Dec 8, 2004 09:01 PM
