TAD Missing
Old Dec 21, 2013 | 11:08 AM
devbravo's Avatar
devbravo
TAD Missing
I had a TAD(Thermactor Air Diverter) valve (I think). At any rate I was in the process of replacing the oil pan and valve cover gaskets, new spark plug wires, coil, and rotor cap, when I noticed that the TAD was missing.
I've got one on order from a Ford dealership.
Will the fact that the TAD is MIA cause any problems if I start the engine and run it?
Thanks
Guy
Old Dec 21, 2013 | 01:51 PM
Conanski's Avatar
Conanski
Are you talking about the valve or the solenoid that controls it? The only part of the system the computer knows even exists is the solenoid but even then it's absence will do nothing more than set a low priority code.
Old Dec 21, 2013 | 04:51 PM
devbravo's Avatar
devbravo
Thanks for your reply Paul... I forgot to mention that it is the solenoid.
I have the Thermactor Air Bypass Solenoid. I'm apparently missing the Air Diverter Solenoid. But as I look at the Thermactor valve assembly ..it looks
like a "single" Valve is doing "double-duty" i.e. working as both the Air Bypass and Air Diverter valves
I'll go ahead and start it and do a test drive.
Thanks again
Guy
Old Dec 21, 2013 | 05:01 PM
timbersteel's Avatar
timbersteel
Yeah, that is the combined assembly. Did you recently buy this truck and find it this way? As Paul mentioned, it'll throw a low priority code when the PCM goes to energize the solenoid if it doesn't find it.
Old Dec 21, 2013 | 05:32 PM
danr1's Avatar
danr1
Not sure but believe it has all to do with cubic inch displacement? but might be wrong....
My 351 doesn't have the Thermactor Air Bypass valve it never did, it had no tube directly down to cat, tube to back of each exhaust manifold only.
It has the Thermactor Air Diverter only, directs air either to atmosphere or into manifolds handling both jobs all in that single device.
460 on the other hand (both trucks over 8500lbs gvwr), 460 has air via tube down to cat or to manifolds.
No air required the Thermactor Air Bypass valve dumps it to atmosphere right behind the air pump, air required system either sends into manifolds or down directly into the Cat via the Thermactor Air Diverter mounted up on the engine. system uses both valves rather than just one, the when and why part I don't know never got into it that deep. That air feed directly to cat or into the manifolds instead part.
351 I eliminated the cat and later remainder of air system, don't get any codes even though vac lines are gone with it, left its control solenoid electrically active.
As Paul pointed out only aspect of the system the computer is aware of, the tab/tad solenoid/s, retain it get no codes.
alloro
Apr 28, 2015 09:59 AM
OldKingCole
13
Apr 30, 2014 08:42 PM
j540
Aug 1, 2012 08:54 PM
krazdndenver
Aug 29, 2002 04:43 PM
