ScanGauge II
Old Dec 21, 2013 | 09:22 AM
born2climb's Avatar
born2climb
Trailering
ScanGauge II
I'm thinking about getting a ScanGauge 2 for my 2006 Super Duty F250 (6.0). Is there anything I have to buy in addition to the ScanGauge, or is the truck prewired with all sensors needed to monitor the 6.0 common issues? And is it somewhat self-explanatory, or does one need an engineering degree to use it?
I posted this earlier in the Super Duty forum...then realized I might get more help here!
Old Dec 21, 2013 | 09:30 AM
npccpartsman's Avatar
npccpartsman
You don't need anything unless you want to get a mount of some kind. All you need to do is plug it into the OBDII port.
Here's a list of SGII PID's that we've compiled that are useful on your 6.0. The only things the SGII won't monitor are engine lubricating oil pressure, exhaust gas temperature, and fuel pressure. The SGII comes with engine coolant temperature preloaded as fWt (water temp in farenheit).
GAUGE TXD RXF RXD MTH NAME
FL 07E02216C1 0462451606C1 3010 000101480000 Fuel Level
VRF 07E0221155 046205110655 3010 006433330000 VREF (CALIBRATION VOLTAGE INPUT)
BAT 07E0221172 046205110672 3008 000100010000 BATTERY VOLTAGE
ECT 07E0221139 046205110639 3008 000200010000 ECT Degrees F
EOT 07E0221310 046245130610 3010 00090005F060 EOT Degrees F
TFT 07E1221674 046205160674 3010 000100080000 TFT Degrees F
IAT1 07E0221123 046205110623 3010 000100010000 IAT1 Degrees F
IAT2 07E02216A8 0462051606A8 3010 000100010000 IAT2 DEGREES F
MAT 07E02216E0 0462051606E0 3010 001200050020 Manifold Air Temperature (*F)
ICP 07E0221446 046205140646 3010 003900640000 ICP PSI
ICV 07E02216AD 0462451606AD 3010 004827100000 ICP voltage
IPR DC% 07E0221434 046285140634 3008 0DCA03E8000A IPR %
INJPW 07E0221410 046245140610 3010 044C04E2FFF1 FPW Microseconds (table)
INJPW 07E0221410 046205140610 3010 000800010000 FPW Microseconds (modified)
ITM 07E02209CC 0426850906CC 3010 000A00400000 INJECTOR TIMING BTDC (DEGREES)
MFD 07E0221412 046245140612 3010 006400100000 MFDES Mg per Stroke
MFD 07E0221412 046245140612 3010 000100100000 MFDES (ALT)
VFDES 07E0221411 046245140611 3010 006400100000 VFD Cubic mm
MAF 07E0221671 046245160671 3010 000100010000 Mass Air Flow (Gram/S)
MFV 07E022177 046245110677 3010 000100250000 MAF Voltage (volts)
FMP 07E02209D0 0462450906D0 3010 006401000000 FICM Main Power (Volts 47-48)
FVP 07E02209CE 0462450906CE 3010 006401000000 FICM VEHICLE POWER (SHOULD BE 12 VOLTS)
FLP 07E02209EF 0462450906CF 3010 006401000000 FICM LOGIC POWER (SHOULD BE 12 VOLTS)
FSN 07E02209CD 0462050906CD 3601 000100010000 FICM-sync 0=NO, 1=Yes
SYC 07E02209CD 0462050906CD 3000 000100010000 SYC CAM/CRANK POSITION SENSOR SYNC (1= IN SYNC)
SYC 07E02209CD 0462050906CD 3001 000100010000 SYC ALTERNATE
SYC 07E02209CD 0462050906CD 3701 000100010000 SYC ALTERNATE
FSS 07E022099F 04620509069F 3010 000100040000 FAN SPEED SENSOR
FDC 07E022091F 04624509061F 3010 013103E80000 FAN SPEED DUTY CYCLE
Baro 07E0221127 046285110627 3008 003100500000 BAR Inches of Mercury
EBP 07E0221445 046285140645 3010 001D00500000 EBP PSI
EBP 07E0221445 046285140645 3010 001D0050FFFB EBP (-0.5 PSI)
BST 07E0221440 046285140640 3010 01220320???? PSI/BST MAP Modified signal PLUG IN VALUE FROM TABLE FROM YOUR MAP
MAP 07E0221440 046285140640 3010 012203200000 MAP EXTENDED RANGE
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
Misky6.0's Avatar
Misky6.0
If plugs right in to the computer port, called odb2, nothing else required. I bought the optional blendmount (just google it) to mount it to the rear view mirror, it comes with extension cable too.
The computer does not monitor, and thus not readable by any device via odb port:
Exhaust gas temp
Low pressure oil pressure
Fuel pressure
Great investment to being able to keep an eye on your engine
Sent from my Sprint PC36100 using IB AutoGroup
Old Dec 21, 2013 | 09:31 AM
npccpartsman
If you read the manual you'll find it's fairly easy to plug in the X gauges just be careful and take your time or you'll have to go back and edit if they don't read properly.
Old Dec 21, 2013 | 09:34 AM
Misky6.0's Avatar
Misky6.0
Entering the xcodes is pretty simple, once you get over the "what do i do now" hurdle, its simple '80s era tech to enter the special 6.0 xcodes, only two or three buttons to push so just push them to learn..
Old Dec 21, 2013 | 09:35 AM
Misky6.0's Avatar
Misky6.0
Lol, is there an echo on here?
Old Dec 21, 2013 | 09:44 AM
born2climb's Avatar
born2climb
Trailering
So does it come with a mount at all? How was it originally intended to be mounted?
(And thanks for the replies!)
Also...@ npccpartsman....concerning the "PIDs" you listed....are they something I have to program into it? Or are they existing "monitors" already programmed in?
Old Dec 21, 2013 | 09:49 AM
Green96's Avatar
Green96
The PIDS will have to be programmed in but it is very easy. It is basically tapping buttons. The only mount that it comes with is velcro, which is fine, but I would recommend buying more than what comes in the kit. The other mounts that you can buy, usually on amazon just look alot nicer, especially the Blendmount that has been mentioned here.
Old Dec 21, 2013 | 09:56 AM
born2climb's Avatar
born2climb
Trailering
How heavy is the unit? I prefer under-dash mounting to mirror mounting. I thought about ordering the ScanGauge, then fabbing a mount once I see what I'm dealing with.
Old Dec 21, 2013 | 10:00 AM
Green96's Avatar
Green96
Very light. Like I said, just buy more velcro and you should be fine with mounting under dash. That is the way I did it. I wanted to be able to see it but for it to be out of the way.
Old Dec 26, 2013 | 08:22 AM
born2climb's Avatar
born2climb
Trailering
Got my Scan Gauge in Tuesday (as in arrived, not INstalled). How do you measure the EOT/ECT delta? I see a code for EOT, but not for the ECT. Is there a code for the delta, or do you have to find a code for ECT and do the math?
Old Dec 26, 2013 | 08:49 AM
jswartz84's Avatar
jswartz84
ECT will be a pretty programmed PID and is labeled fWT.
You must do the math.
Old Dec 26, 2013 | 08:53 AM
Green96's Avatar
Green96
Coolant Temperature is already in the SGII. It is name fWT. That stands for Farenheit Water Temperature. Just compare the EOT and the Water Temperature and the Oil should not get more than 15* warmer than the water. If it gets any warmer then it is a sign of Oil Cooler getting plugged up on the water side. You can test this on a flat road where you can sustain a steady 65-70 mph for about 15 min unloaded. By this time the temperatures stabilize and you can get a true reading of the difference.
Old Dec 26, 2013 | 09:20 AM
born2climb's Avatar
born2climb
Trailering
Thanks, guys! I need a book of all the acronyms associated with this Ford!
Old Dec 26, 2013 | 09:27 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Here ya go
Acronyms
https://www.ford-trucks.com/forums/821641-acronyms.html
