This doesn't look right
Old Dec 20, 2013 | 07:57 PM
LArifleMAN's Avatar
LArifleMAN
Among the many issues I have been having with my 91 F150 5.0 2WD, I noticed this today.
Passenger side
Driver side
Something doesn't look right. There is a noticeable wobble when going 30-35mph and then again around 50mph.
Any ideas?
Old Dec 21, 2013 | 02:05 PM
Conanski's Avatar
Conanski
What doesn't look right to you? There's nothing jumping out at me.
Old Dec 21, 2013 | 02:34 PM
danr1's Avatar
danr1
Nothing to me either other than the locking tab bent down out of place, rather useless/redundant piece anyway IMO...
Someone probably bent it down rather than loosen it make adjustment, didn't bother bend it backup, either that or got snagged on something at some point.
Unless that's it, one missing other side?
Old Dec 21, 2013 | 03:30 PM
Puddy's Avatar
Puddy
Looks fine from others. Just the one on the pass. Side
Old Dec 21, 2013 | 04:09 PM
danr1's Avatar
danr1
That's what I mean perhaps questioning the difference, wonders if supposed to have one other side too, reason for those two pictures.
Old Dec 21, 2013 | 05:05 PM
timbersteel's Avatar
timbersteel
I would jack the front up and give each side a good shake. Those ball joints look original, and good chance they're due for replacement. I just noticed my driver side balljoint on my 300, has slop and its original. Luckily, I had the passenger replaced in 04 and its solid.
Old Dec 21, 2013 | 08:52 PM
LArifleMAN's Avatar
LArifleMAN
Ah, OK, I'm not the most mechanical person and I saw the tab hanging down. As for the ball joints, would that possibly cause the wobble at the aforementioned speeds?
Old Dec 21, 2013 | 08:58 PM
Eddiec1564's Avatar
Eddiec1564
Tie rod ends and drag links are mostly likely a cause of wobble. Ball joints would be next.
Have someone wiggle the steering wheel back and forth(engine off) while watching the drag links. If you see any slop in them, time to replace them.
zsbjr
6.7L Power Stroke Diesel
35
Nov 17, 2016 09:20 PM
Im50fast
Mar 2, 2016 05:51 PM
Ford_Six
General Automotive Discussion
Nov 17, 2011 12:46 PM
bill11012
34
Aug 6, 2010 02:34 AM
Fat Diesel
20
Jan 29, 2006 04:20 PM
