aftermarket front end
Old Dec 18, 2013 | 07:28 PM
zombiefied 247's Avatar
zombiefied 247
I am thinking of going ahead and buying an aftermarket front end for my 55.... how would i go about finding a shop that knows how to weld this in for me????
Old Dec 18, 2013 | 07:42 PM
topmoo's Avatar
topmoo
Ask and ye shall receive
Look for a hot rod shop or one that specializes in classic cars. Or maybe somebody here is in your area of Indiana and knows of one.
Or you could check with whoever you end up purchasing it from, maybe they have contacts of shops that install them.
Old Dec 18, 2013 | 09:02 PM
Branded's Avatar
Branded
PM sent...
Old Dec 18, 2013 | 10:42 PM
old_dan's Avatar
old_dan
It depends on your skill set. You could consider a bolt-in IFS. If not, do everything yourself except the welding....hire in a local guy with a portable rig to do your welds after you get everything fit and clamped into place.
If that's not the plan and you want to hire out the job, wait until someone weighs in with a reputable shop.
One thing I can warn you about....we hear time and time again about guys who drop off their car or truck for modifications. There are a lot of shops who will take your money and not do the work. If you take it somewhere, set up a schedule and include progress payments for significant milestones. If your guy balks at that it's because he was going to take your money and put your truck in the back of the shop as a winter project....probably winter of 2015. Be sure to check references before you choose a shop. It would be fair for your shop to charge you up front for the IFS kit. A couple of logical progress points are to prep the frame...remove existing suspension and steering. Second step is to set up and weld in the crossmember. A third step is to paint everything and install the control arms spindles springs, brakes and set the ride height. The last step is to put the front clip (fenders and hood) back on. Your guy will need to pull the engine to put in an IFS and that is a good idea.
Dan
Old Dec 19, 2013 | 06:18 PM
rhopper's Avatar
rhopper
Old Dan is right as usual. Beware the shop that has tons of cars covered in dust with no visible progress being made. If you can find a buddy with any kind of welder to tack it in the correct spot you can hire a pro to do the structural welding. The rest of the project, painting, bolting on parts etc is within the skills of the average gearhead.
Old Dec 19, 2013 | 06:57 PM
zombiefied 247
thanks for the info and for letting me know what to look for..... I appreciate the help you guys rock
Dec 1, 2017 07:45 PM
rrkF-1
Dec 10, 2012 04:04 PM
uliman
Nevada Chapter
Jun 10, 2008 07:43 PM
mrfox0246
New Jersey Chapter
May 17, 2007 04:00 PM
krazz
Sep 21, 2006 06:54 PM
