turbo seal help?
Old Dec 18, 2013 | 06:28 PM
ldj's Avatar
ldj
turbo seal help?
05 all stock blue smoke at cold start and usuall cold engine sounds and stutters, just started this winter,smokes till reaches 190 ot\\\then no smoke,no smoke if plugged in overnight,no dtc's, no oil usage noticeable no coolant loss,ficm 49 volts, im leaning toward turboseal.
Old Dec 18, 2013 | 06:30 PM
npccpartsman's Avatar
npccpartsman
Unclamp the down pipe (not the y-pipe) from the back of the turbo and check it for oil. If the turbo is leaking it will be readily visible there. If it's dry it's not your turbo. I'd be thinking more along the line of injectors
Old Dec 19, 2013 | 05:15 PM
ldj's Avatar
ldj
first code p0404 today
Old Dec 19, 2013 | 06:11 PM
npccpartsman
Pull and clean your EGR valve. That might cause a little smoke and stuttering too. If that doesn't cure your issue then try some archoil 9100.
olbattlebuggy
May 14, 2011 04:03 PM
mikeast
Mar 30, 2011 08:54 PM
Get Pumped Saltwater
Feb 22, 2011 06:55 PM
powellbound
Jul 15, 2004 07:30 AM
spitball
May 28, 2004 08:20 PM
