99 explorer not blowing air
Old Dec 18, 2013 | 04:14 PM
powerstroke79's Avatar
powerstroke79
I have a 99 explorer that stops blowing air when I get on the gas or climbing a hill. The motor is still blowing but it stops air coming out the vents. Does anyone know what could be causing this? It works fine other than that.
Old Dec 19, 2013 | 06:42 AM
shorod's Avatar
shorod
Sounds like you have the manual (****) HVAC controls rather than the electronic controls. Several of the "doors" in the manual system are controlled by vacuum. The default position for the doors is to blow on defrost. What's likely happening is you have a bad check valve in the vacuum supply for the HVAC system. When the engine is under load, the vacuum drops and the bad check valve allows the vacuum that would otherwise keep the door in the Panel or Floor position to close fully to the Defrost position.
-Rod
Old Dec 19, 2013 | 09:10 PM
steve(ill)'s Avatar
steve(ill)
check small vacuum lines under the hood for hard/ crack / broken ends. Anywhere you have a vacuum leak is suspect.
Old Dec 21, 2013 | 05:35 AM
oneowner83's Avatar
oneowner83
There's a vacuum tank that is a reserve to provide vacuum when you get on the pedal. I believe its a sphere and under the hood.
bunruh
Nov 23, 2022 11:46 AM
CLINT-THE-GREAT
Sep 13, 2013 04:05 PM
ivorycruncher
May 19, 2007 12:01 AM
Snaderi
Jul 24, 2003 02:16 AM
