I am only going on what my local garage told me, that it was necessary to realign.
If you're simply breaking the union of the ball joint and the spindle then you won't need to realign. If you're adding a leveling kit then you WILL need to align, or if you are replacing the control arms.
Don't even need to buy a spring compressor... Major chain parts stores will loan the cheap ones to you for free. But they are cheap ones and you need to be careful using them, but they do work. I used them to change struts on my 04 F150 and wife's Aviator this year. Took a whopping 2 hours to do each one.
On the alignment issue, if the new struts / springs change ride height of the front of vehicle, you should get an alignment. If height is not changed, no need for the alignment. I get an alignment twice a year, so did do it when I changed the components, since it was due anyway. Tires are too expensive and the pot holes in the NE are big, so the alignment is a regular maintenance and cheap insurance for me.
"Don't even need to buy a spring compressor... Major chain parts stores will loan the cheap ones to you for free. But they are cheap ones and you need to be careful using them, but they do work. I used them to change struts on my 04 F150 and wife's Aviator this year. Took a whopping 2 hours to do each one. "
Yes you can borrow the compressor from the auto parts places, but I'm not fond of the separate rod types they loan out. The clamshell type is a lot more stable (safer in my opinion).
Will it also work on Ford struts, or only Mcpherson ones?
'McPherson Strut' is the generic name of a heavy-duty shock absorber that replaces the upper control arm in a vehicle suspension and containing the suspension spring.
Yes you can borrow the compressor from the auto parts places, but I'm not fond of the sparate rod types they loan out. The clamshell type is a lot more stable (safer in my opinion).
I've already got an air compressor, but no clamshell thing,...
