Torque Pro Help
Old Dec 17, 2013 | 02:20 PM
copsey's Avatar
copsey
Torque Pro Help
I'm having an issue getting any FICM readings from Torque Pro. I've checked and double checked the PIDs and I am getting nothing from them. Today was the first time I've hooked up the b/t OBDII and I am getting a connection as I was able to see CEL P1000, P0403 and P0405.
The Excursion also had an odd idle, it would idle normally for 10-15 seconds then drop and come right back to normal idle. ***Please note this only happened when the b/t OBDII was connected to TP***
The Excursion is a 2003 6.0 with Edge Juice Module (installed by previous owner)
Any help would be very much appreciated, I'm sure I'm overlooking something simple.
Last edited by copsey; Dec 17, 2013 at 04:41 PM. Reason: added information on odd idle
Old Dec 17, 2013 | 04:37 PM
npccpartsman's Avatar
npccpartsman
Here's a bump to the top for ya. One of the TP guys will chime in soon, hopefully
Old Dec 17, 2013 | 06:18 PM
copsey's Avatar
copsey
Quick update, FICM voltages displayed fine on the drive home. I'm still getting the odd idle drop though. Also the display on the Edge showed all zeros for oil, coolant and boost, though it did still display EGT.
Old Dec 17, 2013 | 06:22 PM
Misky6.0's Avatar
Misky6.0
Sounds like trouble communicating with the pcm. Although i don't use the torque app,
Shutdown app
Shut off truck
Unplug odb adapter.
Plug in adaptor
Start truck
Start app
Sent from my Sprint PC36100 using IB AutoGroup
Old Dec 17, 2013 | 06:28 PM
copsey's Avatar
copsey
Shutdown app
Shut off truck
Unplug odb adapter.
Plug in adaptor
Start truck
Start app
Will try it in the AM on the way to work.
Thanks
Old Dec 18, 2013 | 03:28 PM
copsey's Avatar
copsey
Any ideas on the rough idle with Torque Pro open? Leaving the OBDII plugged in with Torque Pro turned off the stumble goes away.
Old Dec 18, 2013 | 04:29 PM
Money-Pit's Avatar
Money-Pit
How is the edge juice installed?
Old Dec 18, 2013 | 04:48 PM
copsey's Avatar
copsey
I checked it over, looks to be installed per the install instructions I found online. No running issues with the truck with the Edge installed, that much I can say. This just has me confused because as quick as I shut down Torque the idle drop stops.
Old Dec 18, 2013 | 05:28 PM
Money-Pit's Avatar
Money-Pit
I know nothing about the edge juice, so pardon my ignorance. is the edge supposed to be plugged in the OBD port at all times? I have the torque pro but No tunes, & I have no issues with it. Have you tried to remove the edge and see how it acts?
Old Dec 18, 2013 | 06:17 PM
copsey's Avatar
copsey
The Edge is installed inline to the middle PCM connector, it is not connected to the OBDII. I will remove the edge this weekend.
Old Dec 18, 2013 | 06:40 PM
Misky6.0's Avatar
Misky6.0
I believe that programmer is known to ruin your transmission. Lots of posts saying get custom tunes vs. The canned ones like that edge.
It's an old, popular, and expensive leason learned by many before you.
Welcome to fte, hope you learn some things that help keep you happy with you 6.0.
Old Dec 18, 2013 | 07:48 PM
copsey's Avatar
copsey
Thanks for the heads up Misky. Loving the truck so far. Who do most recommend for the tune or tuner?
Old Dec 18, 2013 | 08:10 PM
diesel_dan's Avatar
diesel_dan
Back to Torque: what odbII connector do you have? Have you tried adjusting the Comm settings on the Torque side? When I saw your posts on not getting/ then getting data, that can be setting the data acquisition rate too fast or allowing Torque to try to find the fastest rate it can on its own.
On the rough running whenever Torque is active: It'd be a reach for me to think that Torque would have a higher priority than the PCM itself on requests for data versus requests/commands from the PCM, but certainly not out of the realm of possibilities. I'd slow the Torque requests down and possibly try another odbII BT connector (they're cheap).
Have no clue how a tuner and Torque get along, not planning on running a tune, unless I stud it....
I am planning on getting a larger Droid device soon
imq707s
Aug 23, 2019 09:22 PM
347stang
2004 - 2008 F150
Jun 7, 2009 10:25 PM
BuickTurbo
Nov 20, 2005 03:10 PM
treb
1983 - 2012 Ranger & B-Series
Sep 4, 2003 05:36 AM
bigric
1978 - 1996 Big Bronco
Jul 7, 2003 11:53 AM
