Those with the Edge Evolution...Question.
Old Nov 13, 2005 | 09:26 AM
BuickTurbo's Avatar
BuickTurbo
I am showing 15.3 psi of exhaust backpressure at idle. Does anyone know where this reading is taken? -pre turbine/post turbine.
What position is the EBPV supposed to be in when not functioning?
I suspect a stuck valve. I get up to 35 psi of backpressure when under load.
I would think that if the EBPV was open, there would be realatively no to little backpressure readings.
Old Nov 13, 2005 | 09:55 AM
Kwikkordead's Avatar
Kwikkordead
There should be no backpressure at idle. If your EBPV is closed you would be able to hear it hissing, even at idle.
Old Nov 17, 2005 | 02:05 PM
WMDPSD's Avatar
WMDPSD
my ebpv is not working right now, but I can tell when it is closed. at an idle with it opened I still get 13.8 or so. don't know if that will help but there it is
Old Nov 17, 2005 | 02:20 PM
Kwikkordead
Well that doesn't make sense. If you truly had 13 psi of exhaust drive pressure there would be 5 psi of boost at idle! Gotta be a bad sensor or something wrong with the way that the Edge is reading things.
Old Nov 17, 2005 | 06:22 PM
stroker2's Avatar
stroker2
I just posted some info I found on dieselmanns web site about the EBP sensor and valve. It's on the EBPV problem thread. From what I've read, the Evolution gets the exhaust back pressure reading / value from the EBP sensor which it's reading from the passenger side exhaust manifold, pre-turbo. So it's really a exhaust manifold pressure reading. A dirty tube to the EBP sensor will give inaccurate values if I understand it correctly.
Old Nov 18, 2005 | 09:35 AM
stroker2's Avatar
stroker2
Sorry BuickTurbo, don't mean to hijack your post, but I just had another thought regarding the Edge Evolution monitor / programmer. I assume it gets the boost reading from the MAP sensor and it gets the back pressure reading from the EBP sensor (exhaust manifold pressure), you can then do a comparison between pressure into the turbo and boost output. I think you can even monitor them both on the same screen. If the 2:1 ratio is correct, your 35 psi "back pressure" (exhaust manifold pressure) under load should be about 17.5 psi boost, which sounds about right. As a diagnostic tool, if that relationship is ever off by alot, it could mean you have a sensor problem, a problem with your turbo, boost leak, etc.
I don't have an Evolution, but they intrigue me. Maybe when I win the lottery I'll get one.
Old Nov 18, 2005 | 03:03 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i bought one about two days ago, i am stacking it with my Juice. hopefully i can make the transmission "harder", with more of an RPM drop between shifts. i also want to bark the tires when shifting. $300 new, off ebay.
Old Nov 20, 2005 | 02:36 PM
BuickTurbo's Avatar
BuickTurbo
Stroker2 you are forgiven.
As for barking the tires Stroke, If I can do it in a dually.......I can actually bark 3rd because the 1 to 2 shift the wheels are still going, then I back out of it to catch earth and chirp away third. I don't do this often, but it's fun at a stoplight. I wish I could see the faces behind me, but it's a PSD.
Old Nov 20, 2005 | 03:10 PM
PowerstrokeJunkie
cool!
do you by chance have the sonnax valve and tricumulator springs?
after you added the evolution, did you notice a more manual-like transmission? by that, i mean does it drop rev's more when shifting, as if there is more line pressure?
