need help with diagnosis
178,000 miles. normally truck runs perfect, never a hiccup, with the exception of high idle at start up that slows to normal after a few. Now starts with low idle and stays low, seems to try and find shift points up and down, dieseling during acceleration, but can limp home. My thought would be one of the sensors. Any suggestions?
Warm up the engine then do this: Fuel Injection Technical Library » How To Run a Self-Test
Or purchase a code reader such as the Equus 3145.
Then when the key is turned on the self-test KOEO test will start and you can count the flashes on the CEL/MIL lamp in your cluster.
The frame is not a ground point and may or may not be grounded depending is the right NEG ground cable was replaced or not.
KOEO:
DTC 122 indicates the Throttle Position (TP) sensor signal is less than the Self-Test minimum value.
Possible causes:
TP sensor may not be seated properly (tightened down).
Damaged TP sensor.
Open harness.
Grounded harness.
Damaged Powertrain Control Module (PCM).
CM:
CONTINUOUS MEMORY DIAGNOSTIC TROUBLE CODE (DTC) 122: MONITOR TP CIRCUIT UNDER SIMULATED ROAD SHOCK
Connect VOM or Super Star II Tester to STO.
Observe VOM or listen for beeper to sound on Super Star II for indication of a fault while performing the following:
Move throttle slowly to WOT position.
Release throttle slowly to closed position.
Lightly tap on TP sensor (simulating road shock).
Wiggle TP harness connector.
Continuous Memory DTC 332 indicates the EGR valve did not open with the engine stabilized and the EVR solenoid duty cycle present sometime during vehicle operation.
Possible causes:
Obstructed or cracked hose to EGR valve.
Icing.
Damaged EGR valve.
Damaged EVR solenoid harness.
Key off.
Disconnect vacuum hose at EGR valve and connect a hand vacuum pump.
Apply 10-20 in-Hg (34-67 kPa) to EGR valve.
Does EGR valve open and maintain vacuum?
KOEO:
Possible causes:
Damaged TP sensor.
Open harness.
Grounded harness.
CM:
Possible causes:
Icing.
Damaged EGR valve.
Key off.
in regards to the egr, mine looks like if I was to just replace it would be the egr valve and valve position sensor. I will check the vacuum first, but I need to go buy a vac pump before i can check. I do not see an egr solenoid.
Thank you for a perfect straight forward answer. I have been on other forums where the answer tends to be "do a search".
Some auto part stores will rent you a hand vacuum pump.
The TPS is used by the PCM Computer to select gears in the transmission.
Still though these were present in the truck for years, if the tps completely crapped out would it give me the symptoms I am describing, dieseling with throttle, gear searching, and low power.
Here is some information on the EGR solenoid and it is sometimes call the EGR Vacuum Regulator (EVR):
Fuel Injection Technical Library » EGR Vacuum Regulator (EVR)
The PCM is getting bad information from the TPS when you start it and there for it is not opening the IAC valve at start up. So you are getting low idle.
I do not know if the TPS is bad or the plugs and wiring between the TPS and the PCM.
Here is some information on the TPS:
Fuel Injection Technical Library » Throttle Position Sensor (TPS)
Back probe the TPS plug for the 5 volt dc from the Computer and check it to the SIG RTN on the same plug.
Then check the TP wire voltage at closed throttle, mid throttle and WOT.
