400M Timing
Old Dec 15, 2013 | 09:44 PM
Snorri_B's Avatar
Snorri_B
400M Timing
Hi im wondering about the timing on my 400M I just rebult the engine with a compcam 284/284 hyd roller and about 10.4:1 compression ratio ... I have the D.U.I. hei stile diztributator curved for my old setup but i was told i do not have to recurve the dizz but i could run more timing ? i set my dizz on 12 degrees before top dead center .... I had the 272 crane flat tappet before and 9.4:1 compression ....
Old Dec 16, 2013 | 10:34 AM
BuzzLOL's Avatar
BuzzLOL
. The higher compression ratio may want less timing and less aggressive curve, but the bigger cam prolly more timing advance and more aggressive curve, so only some experimentation for best power/results will likely give you a correct answer...
Old Dec 16, 2013 | 10:48 PM
Snorri_B's Avatar
Snorri_B
Okey so i could set it at 13-16 BTDC ... total timing on the diss is 24 degrees at 3000 rpm
Old Dec 17, 2013 | 01:22 PM
BuzzLOL's Avatar
BuzzLOL
. 24 degrees sounds low for total timing (unless using blower/nitrous)... usually more like:
(Fast Burn Heads/High Compression ratio) 30 degrees - 40 degrees (Low compression ratio/open chamber heads) range
. Initial timing plus mechanical/computer advance = 30 - 40 degrees range
Old Dec 19, 2013 | 12:01 AM
Snorri_B's Avatar
Snorri_B
Sorry ment to say 24 degrees max advance at 3000 rpm 12 degrees at idle
Old Dec 19, 2013 | 01:10 PM
BuzzLOL's Avatar
BuzzLOL
. Oh, OK, just keeping you honest... LOL!
tygerrrr
Aug 29, 2009 02:01 AM
hoxiii
Alternative Fuels, Hybrids & Mileage
Mar 7, 2007 11:35 PM
jwgeorge
Aug 28, 2005 01:45 PM
mustangman65_79
1978 - 1996 Big Bronco
Dec 31, 2003 01:37 PM
Kemicalburns
Nov 26, 2003 12:24 PM
