no charge
Old Dec 16, 2013 | 05:05 PM
Mowing Man's Avatar
Mowing Man
Not trying to step on toes Bonanza. It's a real possibility the alt could be bad, but to accurately test, you need to disconnect the large charging wire before your meter reading. If the alt is not putting out due to a short in the small wire, your meter will read exactly the same as the batts. The other thing to check is ground wires. They could. Be bad too.
Here's the link. https://www.ford-trucks.com/forums/1...no-charge.html
Old Dec 16, 2013 | 06:19 PM
Bonanza35's Avatar
Bonanza35
That's what I was saying a bad alternator. Don't worry about my toes we'll all just trying to help. My son went threw a couple of reman alternators even though he told Ford to put on new ones. The quality just isn't the same.
Old Dec 16, 2013 | 06:45 PM
Mowing Man's Avatar
Mowing Man
I agree with you. Last march I had the same problem in the middle of a snow storm. Tried 3 alts, from autozone, advanced auto, and napa. None worked. Finally, I pulled the one off my other 7.3 that I knew was working and it didn't work. That's when I learned about these wires on the small clip, lol. FYI. I popped the hood and the two wires are- green/red stripe, and orange/gray stripe. Orange and gray wire needs to show voltage in order for alt to put out a charge. Blown fuse, fusible links blown, or stripped wire will prevent this. If you are in a pinch, you could run a temp. Jumper wire from the + batt terminal, but it probably should have some kind if fuse in line. Not sure what that would be. Knowing how I am, I'd probably throw a 20 amp fuse in a universal holder and hope it held, lol. Gets you where your going at least.
Old Dec 17, 2013 | 12:32 PM
bcaughhorn's Avatar
bcaughhorn
Both wires on his plug are green with orange I believe. We checked the plug also. One wire Is hot the other has nothing. I questioned the alternator too after having to replace both of mine at the same time. He said he took it back and they bench tested it
Old Dec 17, 2013 | 01:38 PM
tommyl's Avatar
tommyl
My '99 F350 has a(unused) wire harness for a second alternator laying under the starter solenoid (passengers side fender). The plug end has a short wire loop installed, it had shorted out, thus alternator would not charge.
Old Dec 17, 2013 | 01:43 PM
bcaughhorn's Avatar
bcaughhorn
Ok. We will check that too. Thanks
Old Dec 17, 2013 | 02:13 PM
tommyl's Avatar
tommyl
I went to Walmart and bought a digital readout gadget that checks the alternator and batteries, just plug it into the cig/lighter. Also picked up a female socket with two clips on the end of the extruding wires that I can clip on the battery or the alternator. Presto, now I have a digital readout gauge for trouble shooting.
Old Dec 17, 2013 | 04:30 PM
lhud's Avatar
lhud
The voltage regulator in the alternator may be bad - the diodes can fail and cause it to not charge. Every morning it takes a minute or so for the voltage regulator to kick in and start showing a charge - that's quite normal.
It could also be brushes inside but I would suspect the regulator first.
651_F350_KR
Apr 26, 2016 09:01 AM
maxtruck00
Jul 18, 2015 04:32 PM
Shutech
Apr 21, 2015 09:31 PM
sls985
Mar 27, 2003 07:28 PM
