Belts Squeal When Cold
Old Dec 13, 2013 | 11:55 PM
Subzero68's Avatar
Subzero68
On my new to me F250 that I just bought I noticed the belts squeal when the engine is first started until it warms up good. Other than that its all good. The truck has 202K on it now and I'm still trying to find a service book. When and how can I tell if they need to be changed out?
Thanks
Old Dec 14, 2013 | 12:06 AM
jswartz84's Avatar
jswartz84
Not knowing if its ever been changed, just change it out and put the old one in the tool box for emergencies.
Old Dec 14, 2013 | 12:16 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Yep, try a new belt. If that doesn't stop the squeal it's time for a new tensioner.
As a side point, on cold start, check to see if the a/c compressor isn't locking up. The a/c is active on defrost mode and upper/lower vent setting.
Josh
Old Dec 14, 2013 | 10:11 AM
Subzero68's Avatar
Subzero68
Sounds like a plan, I'm going to go see how much it'll cost.
Old Dec 14, 2013 | 05:23 PM
diesel_dan's Avatar
diesel_dan
Good luck on fixing that squeal. I had mine into the dealer 4 times over several years for the exact same thing (under warranty). After the second belt still made noise (like yours, only when stone cold), they said they had a "bad run" of belts. Another winter and there it is again -- last time I had it in they did the tensioner and belt and it still squeaks when cold. But only winter cold, it's quiet in summer, and only on first start, once warm it's all quiet.
If it bugs me enough this winter I think I'll try a Gates or Goodyear belt and see what happens -- you might want to try that right off the bat, as all of mine were factory ford belts...
Old Dec 14, 2013 | 05:59 PM
Subzero68's Avatar
Subzero68
That's exactly what mine does, once its started up its never made any noise. I'll order a gates belt and see what happens. I haven't looked into the procedure to change them out yet, how many should I change out? Would using some belt glaze stop squeak hurt anything?
Old Dec 14, 2013 | 07:09 PM
69cj's Avatar
69cj
A lot of people have had good luck with the Goodyear Gatorbacks.
Old Dec 14, 2013 | 09:03 PM
Subzero68's Avatar
Subzero68
Would this belt fit? Goodyear Gatorback Poly-V Serpentine Belts 4081331 - Free Shipping on Orders Over $99 at Summit Racing I saw multiple sizes and I'm not sure as to which I need.
Old Dec 14, 2013 | 09:04 PM
diesel_dan's Avatar
diesel_dan
I like the design of the Gatorbacks -- I put one on the Expy when I did the Alt. Only thing is.... Is that it makes it's own noise -- kind of a whirr/whine, you really only hear it at idle, and I doubt you'd even notice it on a 6.0....
Karlow
Jul 11, 2017 08:28 PM
JeepGuy93
Apr 30, 2017 07:24 AM
DavidS827
1997 - 2003 F150
16
Aug 27, 2012 02:54 PM
leejk
6.4L Power Stroke Diesel
16
Aug 2, 2010 06:02 PM
abah
2004 - 2008 F150
Feb 24, 2006 09:13 AM
