towing over 10k with 3.73?
#31
Sorry late to the party but if you want charts here's ya some
https://www.ford-trucks.com/forums/1...xle-ratio.html
#32
Thank you, everyone, for your input. I am now the proud owner of a 2011 f250 lariat. Only had 3875 miles when i pulled of the lot. The only downside is it is 2wd but it was $5k less then a similarly equipped 4wd with 22k miles. I drove it home yesterday. This is the only pic i have. The cap will come off and get repainted to match. Very happy so far. I cant wait to hitch up to something. Intitial impression is that it feels more powerful at any rpm, 1k - redline, then my 5.4 with 4.10s and 93 5 star tune. If i want to regear to the 4.30 i only have 1 axle to worry about but the 3.73 feels strong.
#33
I tow a 11000 lbs. trailer all over Illinois, Indiana and Kentucky with a 3.73 and it does a fine job, but I would rather have a 4.30 I can see a need. You guys that lock out 6 gear thinking you’ve turned your truck into a 4.30 I’m not following you, all you’ve done is turned a 6 speed transmission into a five speed. The 4.30 is needed for start up not cruising and it gives you improve pulling through every gear including six gear. Also when I tow, I leave it in drive with all gears in, when it can on at or about 65 mph on flat land six gear will come in and cruise very nice.
I have looked into changing my ring and pinion gear out for a 4.30 at my local Ford dealership and they want $1800 plus tax. But Ford says that any changes from original from the factory could bring warranty issues, whatever that means.
Happy New Year everyone.
#34
So is the dealer implying that a " dealer changed ring and pinion will not cover issues"? I have often wondered about that.
At some point when my factory tires are shot I plan to change my wheel an tire package. I would like to run 35's but I am also concerned how the truck will act since it is changing my overall gearing ratio.
If the warranty stayed the same and I could pay the dealer I would have them change out the front and rear ring and pinion...... I have not looked into it but if I went to 35's I would like to go to a steeper gear than 4.30's if they were available. This way with 35's and let's say 4.56's (just a guess) i would have closer to a stock setup with 4.30's
#35
No that comes directly from Ford, the dealer wasn't sure how it affected my warranty, I think they like staying out of it. And when you talk to Ford they are very vague they just keep repeating you can't change from stock on anything.
#37
#38
Well, i only towed it for a few miles to test the wd hitch setup after adjusting it to the new truck (the 09 was a 4x4 with 5" rear blocks so it sat much higher). It towed very well. In a couple weeks we are taking a trip to Hershey pa for our anniversary. Its about 375 miles or so and lots of hills so it will be a nice test of the new truck and trailer. So far my only complaint is i greatly miss 4wd. Other then that its a great truck. i upgraded my tuner with new tunes from Mike at 5star with 87 eco, 87 preformance and 93 preformance. I have not tried 93 yet but 87 preformance is alot of fun. Anyway thank you everyone for your input.
#39
#41
My only regret on my truck is not ordering to get 4:30's. When my warranty is up I will weigh very heavily the decision to have the gears swapped. Probably from a specialty shop, not Ford. If they would honor the warranty, I might be willing to pay their inflated prices to have it done, but I guess I'll wait. It tows my trailer fine, but it would be better with 4:30's, and I don't care about the mileage, it's not my daily driver.
#42
^^This is absolutely correct. The part about turning it into a 5 speed is spot on. I know that works for a lot of folks, but just be aware of it.
Denny
#43
But... once operating in a transmission over-drive gear,either 5 or 6, the torque is not magically produce by the 4:30 rear gears...right?
example:
3:73 gears, 5th (1st over drive from transmission) engine operating at 2200 rpm = X torque at wheels
4:30 gears, 6th (2nd over drive from transmission) engine operating at 2200 rpm = X torque at wheels.
in this case X should be equal?
#44
example:
The rear end gears are the last torque multiplier so lower gears will give you more mechanical advantage through all the gears.
Simple example you need to torque a bolt to 1000 you use a 10 to 1 multiplier so you only have to exert 100 ft lbs to get that torque. If you go to a 5 to 1 multiplier you would need 200 ft lbs to gain the same same torque.
Denny
#45
Denny
Denny
I see it this way:
If you are using 6th gear vs 5th you are reducing torque by X amount at the drive shaft
and you are gaining torque by having the 4:30.
If you are using 5th gear you have more torque at the drive shaft, but are reducing torque with the 3:73 by X amount.
this is under the assumtion the engine RPM and speed (MPH) are the same. just the part (gearing) between the engine and the wheels are different
I'm not doing a good job of explaing
