Check engine
Old Dec 13, 2013 | 08:19 PM
timbersteel's Avatar
timbersteel
Exactly as RLA said. That fuse is your ticket if its blown, no way to pull codes. Chevy also has their cigarette lighter fuse on the same circuit for the DLC.
Old Dec 15, 2013 | 11:57 PM
scrobbie's Avatar
scrobbie
What about his vss could this be his problem?
Old Dec 16, 2013 | 07:49 AM
subford's Avatar
subford
It could if he has bad bearings in the rear end.
Old Dec 18, 2013 | 08:05 AM
davidwags3's Avatar
davidwags3
last night my check engine light went on and stayed on so I took it to AutoZone this morning and got it checked for codes. I got back ignition failures. The sheet said check for short circuit, poor wiring connection, or faulty ignition misfire sensor ( I believe this sensor is also the crank position) does that stuff sound correct? I also didn't know if it could be the ignition control module since I'm having odd shifting at times
Old Dec 18, 2013 | 08:13 AM
dixie460's Avatar
dixie460
The crank position sensor on these trucks is only used for misfire monitoring... truck will run fine without it.
The RPM/crank/cam position signal is encoded by the PIP (Profile Ignition Pickup) sensor in the distributor.
Old Dec 18, 2013 | 10:18 AM
rla2005's Avatar
rla2005
Please list the codes by number, PXXXX
Old Dec 18, 2013 | 01:46 PM
davidwags3's Avatar
davidwags3
the code is a P0320
Old Dec 18, 2013 | 01:52 PM
davidwags3's Avatar
davidwags3
The autozone receipt said faulty ignition failure sensor which after research acts also as the crank position sensor and the only way to get to it is to remove the distributor. But when I research the code online many people relate the code to the ignition control module which is the senor mounted on the outside of the distributor. Can anyone help as to which it might be
Old Dec 18, 2013 | 02:08 PM
subford's Avatar
subford
Continuous Memory Diagnostic Trouble Code (DTC) P0320 indicates two succesive erratic Profile Ignition Pickup (PIP) pulses occurred resulting in a possible engine miss or stall.
Possible Cause:
Low battery voltage.
Loose wires/connectors.
Open/Shorted circuits.
Damaged distributor cap, rotor, plugs or plug wires.
Damaged coil, ICM or PCM.
95% of the time this turns out to be a bad PIP sensor mounted on the stator inside the distributor.
Your BLACK ICM is mounted on the drivers fender but very seldom goes bad. But make sure someone has not replaced it with the wrong gray one.
Old Dec 18, 2013 | 05:53 PM
davidwags3's Avatar
davidwags3
I traced the ignition wires, checked distributor cap, and cleaned battery terminals. this is the sensor autozone said could be faulty. can anyone specify what this is and where it is located on the truck. Duralast/Ignition Misfire Sensor (SU2037) | 1996 Ford F150 1/2 ton P/U 4WD 8 Cylinders N 5.0L EFI | AutoZone.com_
Old Dec 18, 2013 | 06:11 PM
rla2005's Avatar
rla2005
No, that is not what you may need to replace. Bill is referring to the PIP (stator) inside the distributor.
For reference: Fuel Injection Technical Library » Stator (RPM)
Old Dec 18, 2013 | 06:16 PM
davidwags3's Avatar
davidwags3
yeah I know that it isn't the PIP sensor he was referring to. I was just wondering what the sensor they showed me was and if maybe it could help my problem
Old Dec 18, 2013 | 06:30 PM
  #28
subford's Avatar
subford
No it will not help you at all.
Sounds like you have PIP sensor going bad but the PIP sensor is not causing your problem either. It may leave you on the side of the road but it should not effect the transmission.
I am not sure they gave you the right code as that code would have nothing to do with the transmission going in and out of OD.
I think I would have some other place read the codes if they did not clear them.
You may have a transmission problem that is not showing codes also. If the transmission problem that you have is not electrical you may not be getting a code yet but give it time and the Computer will come up with a code sooner or later.
Old Dec 18, 2013 | 06:34 PM
  #29
davidwags3's Avatar
davidwags3
The transition is not going in and out of OD it just seems to downshift when the light comes on and the motor seems to act up. Im thinking the code is correct it seems like some sort of misfire but im not sure.
Old Dec 18, 2013 | 06:52 PM
  #30
subford's Avatar
subford
Then I would change the stator (PIP) or put in a NEW distributor, not a rebuilt or a distributor that was remanufactured.
And then see how it runs.
