10W30 Oil selection
It does put some bite in my opinion that the main reason for Mobil 1 these days is at the temperature extremes, which after all, was its "claim to fame" initially. I believe that current refining and additive packages make some regular oils almost as good in other areas; certainly cost effective at 80% less per quart. But if your wife and daughter have to start the truck at 20 below, or pull the horse trailer at 90 (degrees and MPH--well, maybe I exaggerate a little) with the AC on full, and then you expect it to run flawlessly for at least 250,000 miles, then you've got to use Mobil 1.
Interesting about Pennzoil. Maybe they've gone the "lower our costs regardless" route like Fram. I'm hoping Ford doesn't go too far down that path.
As they say on CNBC, in the interest of full disclosure, do you have any relationship with Exxon Mobil?
Kevin
I have to wonder how Pennzoil can have such reported universaly poor performance when it's manufactured from a varied source of base stocks. Pennzoil is a large customer for base stock from other major oil companies such as Excel, Petro Canada, and Chevron RLOP.
And that information doesn't come from my neighbor's brother-in-law. It's documented here. The link is to a civil court decision from the United States District Court of New Jersey. Castrol challenged Pennzoil's marketing claims in a lawsuit and won. But the interesting part about the base oil's can be found under "7. The Double-Length Sequence IIIE Engine Tests, II. Motor Oils, A. Pennzoil's Base Stocks"
Pennzoil's formulations of SAE5W-30 used three different base oils. They are Excel, Petro Canada, and Chevron RLOP. Each of these base oils have been exposed to a Sequence IIIE engine test and meet the minimum standards for classification and licensing established by API and ILSAC. According to API publication 1509, and based on their chemical composition, these base oils are categorized as Group II base oils.
So if we are to believe all the negative hype about Pennzoil, we have to be willing to believe the same about all their supplier's. Who knows? Maybe our favorite brand is a supplier to Pennzoil.
Pennzoil sells millions of gallons of oil throughout the world. If engines were truly sludging up like the ubiquitous "my buddy" lore, they would have been out of business 50 years ago!
Anyone that believes that garbage, come on out to my place, and you can inspect my entire fleet for sludge - you won't find any. And why is that? Because I maintain my vehicles and equipment when I'm supposed to! I don't wait 20,000 miles to change my oil and get mad when the engine falls apart.
And, for the last time, there is no wax in Pennzoil, Quaker State or Kendall!!
As I said in my earlier posts, any one of the major oils will work great for you.
Pennzoil/QS must curse the day they ever decided to use such a misunderstood chemical term in advertising.
Jim
Thanks for the edit horsepuller - I'll endeavor to clean up the language and use of alternate letters...
bearfoot - so in your (what is it 18?) long years of experience, you have seen a total of one engine failure that was supposedly directly caused by Pennzoil, is that your contention? Just want to make sure if that is the factual basis for your argument.
Okay then. Let's deal with facts.
Fact - Pennzoil is the #1 selling gasoline engine motor oil in the U.S.
Fact - Pennzoil's millions of loyal customers actually pay a premium price over Havoline and the other "service station" brands for it.
Fact - Pennzoil doesn't even refine its own base oils. I suspect it doesn' manufacture its own additives either, but I am not certain of this.
Now if you like I'd be happy to write to Pennzoil's tech service department for some additional engine testing and performance factual information which I would be happy to post, but I fear it would bore the heck out of most of us! But I will do it if you want me to.
Now it is your turn -
Why again was your "neighbor" rebuilding his engine?
What kind of car was it? Engine size and mileage?
Can you absolutely guarantee there was no blowby which caused sludge to accumulate in the valve covers?
How were the head gaskets?
Did your "neighbor" have the oil analyzed?
Did he contact his dealer?
I'm sure you have all the data regarding frequency of oil changes, etc. Could you please post that?
Did he ever make a claim of any kind against Pennzoil?
Lastly, I especially enjoyed your comment: what i do know is with the oil i use i can abuse my truck, and flog it to hell and back, over rev it and over heat it, change the oil after the recommended time and mileage and i still wont have any sludge, or build up So, am I correct in saying that it is your position that only non-Pennzoil users abuse their vehicles? Or is it your position (based on your vast experience) that ALL Pennzoil users have a sludge problem? I know you're smarter than that.
Many of the vehicles that go to mechanics and are reported to have sludge build-up have not had the proper maintence done as required. That is what it is due from as opposed to the oil itself.
