P0284 Code with brand new engine.
Old Jan 9, 2014 | 02:33 PM
  #46
Iceman Antarctica's Avatar
Iceman Antarctica
<iframe width="420" height="315" src="//www.youtube.com/embed/YQ3T5DbwPo4" frameborder="0" allowfullscreen></iframe>
Lately, when I crank it up, it sound like this. Not every time though. This sounds more like an injector knock. The idle RPM's are very stable when it sounds like this. Very strange indeed.
Old Jan 9, 2014 | 02:37 PM
  #47
Iceman Antarctica
From the bottom, it sounds like a rod is coming through the oil pan. Sorry for the quickness of the video. I was trying not to smoke up the shop. In the other video, I moved outside and it went back to the usual noise. I wanted to make the video longer but the card was full on the camera and it got cut short.
Old Jan 9, 2014 | 02:39 PM
  #48
mustang_309's Avatar
mustang_309
There is definitely something loose. Have you ran it with the transmission removed? Cracked flex plate maybe? Cracked wrist pin on a connecting rod?
Old Jan 9, 2014 | 02:44 PM
  #49
mustang_309
Have you ran it with the valve covers removed to see if the source is in the valve train? It almost sounds like a flat cam but ive never heard one quite that loud.
Old Jan 9, 2014 | 04:56 PM
  #50
Per4mance's Avatar
Per4mance
If I didn't know better I'd swear it was a cracked piston skirt.
Old Jan 9, 2014 | 08:36 PM
  #51
CPB1's Avatar
CPB1
Try this
Maybe you can verify there is no base engine problem.
Old Jan 10, 2014 | 03:22 AM
  #52
Iceman Antarctica
<iframe width="420" height="315" src="//www.youtube.com/embed/r4-zDGOSmGI" frameborder="0" allowfullscreen></iframe>
Here ya go CPB1. It seems to pass the spin test.
Old Jan 10, 2014 | 08:23 AM
  #53
Iceman Antarctica
Does anybody know the part number for the Ford Blue Spring upgraded fuel pressure regulator kit?
Old Jan 10, 2014 | 08:36 AM
  #54
Mr.Nobody's Avatar
Mr.Nobody
This is without the housing, 6E7Z9C165B
Old Jan 10, 2014 | 09:21 AM
  #55
Mcrafty1's Avatar
Mcrafty1
Maybe this will be of no help but have you tried unhooking 1 injector at a time and isolating the issue to a specific cylinder? or do you already know which cylinder is bad and are just trying to figure out what is wrong with that one cylinder? Also when you did the spin test it almost seemed like the 'knocking' sound was there then too, but with the different audio setup and being inside the garage maybe it would sound a little different anyway.
If you weren't at the end of the world I would suggest you pull that beetch out and ship it back to Fomoco and demand a replacement, let their engineers figure it out. Hope you find the problem soon and get your truck back into service.
Old Jan 10, 2014 | 09:41 AM
  #56
Iceman Antarctica
Is that number just for the spring?
I need the whole kit because the little plastic orifice at the top of the housing is broken. My boss wanted me to remove the broken piece to see if the running improved. I didn't think it would but he insisted. Now the fuel pressure is down to 25psi from 45psi. I can't put the broken pieces back in because the whole thing kinda crumbled.
I found a kit number 3C3Z 9T517 AA that includes the plastic piece but I am not sure if it has the updated spring.
Old Jan 10, 2014 | 09:51 AM
  #57
Mr.Nobody's Avatar
Mr.Nobody
The kit that you posted comes with the housing, the kit I posted does not. They both come with o-rings and the spring, the little brass cup, a small white plastic piece with a very small o ring (I believe this is the part you are talking about), a black piece, new screws. I don't know the technical names for the parts, but either kit has that little part.
Old Jan 10, 2014 | 09:56 PM
  #58
CPB1's Avatar
CPB1
Yea after I posted that I went back to the last video and the start up crank seemed normal.
It looks like you have ruled out everything mechanical. It would seem it must be something electrical or electronic.
Old Jan 12, 2014 | 07:59 PM
  #59
raptor131's Avatar
raptor131
That little white orifice broke on mine as well
Old Jan 13, 2014 | 10:08 PM
  #60
mustang_309
How is your project going? Have you figured anything out with it?
