Hydraulic Clutch
Old Dec 11, 2013 | 08:19 PM
Mthoward's Avatar
Mthoward
Hydraulic Clutch
I have a 96 F250 XL, 351 5 speed, 205k miles. Over its life it has had at least 6 master and slave kits put in for the clutch. Whats up with this? Why would it eat them so much. The last one lasted 2 1/2 years (a record I think) but now it seems to be failing again (pedal stays on the floor, won't go into gear when running, need to add DOT 3). Oddly, I find no fluid in the bell housing. Any thoughts? Is there a conversion kit to non-hydraulic? What engine / xmsn combination is better for durability and repairability? I'd like to keep a manual.
Old Dec 11, 2013 | 10:54 PM
kermmydog's Avatar
kermmydog
Are you buying OEM parts?
Old Dec 12, 2013 | 07:08 AM
blackjack95's Avatar
blackjack95
my 95 250 with 351 4x4 single cab zf 42 seems to be going through slaves as well.i put a new 1 in when i changed my clutch witch i thout was bad but didnt look bad after i removed it.it would slip and smell when taking off in 2nd gear even when on flat surface.so i put in a dual friction center force clutch to prevent the slipping.this still happens every once in awhile.anyway i changed the slave out as well with a dorman slave.not like 3 or so months later it went out and i replaced the slave again.1yr or so later now it seems to be leaking again iv added 2 times now in 2 to 2 1/2 weeks so im wondering if these issues are common as well.
Old Dec 12, 2013 | 10:39 AM
Jarryd's Avatar
Jarryd
I've heard to only use ford slaves. They will last longer.
Old Dec 12, 2013 | 12:14 PM
garthneddy's Avatar
garthneddy
Jarryd heard right. I only use Motorcraft slaves and masters and haven't ever had to replace one due to wear.
When I swapped the ZF5 I foolishly used a NIB O'Reilleys house rand slave and had to replace it after roughly one year of daily driving.
Old Dec 12, 2013 | 06:43 PM
blackjack95
how about the clutch slipping or smelling some when taking off in 2nd?any 1 else have that issue?this is my 1st zf iv owned. iv had 4spd before and they r solid.so far not to impressed with zf other then 5th gear helping on gas mileage.
Old Dec 12, 2013 | 08:02 PM
Mthoward's Avatar
Mthoward
Master / Slave
The last one (lasted 2 1/2 years) was installed at a ford shop, but I was told that OEM parts weren't available anymore. Maybe that was just the clutch only, but I had it all replaced. I'll see if my mech can get an OEM slave. I'm getting tired of this particular problem. Anyone know of a conversion to outside the bell housing slave? Better yet, how about a conversion to a non hydraulic actuator? Really gravels my bum cause I just installed a new BW rollover.
Old Dec 13, 2013 | 06:57 AM
blackjack95
ya its a pain in the a@@.the only way to get a outside slave is a bid block zf trans.but then the only motor it will fit is big block.im thinking of a big block swap.hope some 1 ealse has an idea.
Old Dec 13, 2013 | 09:33 AM
garthneddy's Avatar
garthneddy
There are no other ideas. Keep the hydraulics and use quality motorcraft components and you shouldn't have any issues.
Old Dec 13, 2013 | 10:52 AM
kermmydog's Avatar
kermmydog
Somewhere in the second post here I asked that question. Using OEM parts is in most cases the best choice. They are built to a higher standard to meet the manufactures demand, not so much their specs. Believe me it Ford starts having problems with a parts manufactures they get it fixed, believe me.
Old Dec 16, 2013 | 08:58 PM
Mthoward's Avatar
Mthoward
I think I'm going to buck the trend. The nearest Ford shop is 2 hours away. Local mechanic has a replacement with a lifetime warranty which covers parts and 75% labor. I called Ford and they have a 12 month 12k mile warranty - obviously my last repair is out of warranty. I'm going to chance it with the warranteed part and I'll let you know. Worth trying given the distance to a Ford shop.
I plan on sending this one down the road in a year or so. I need a heavier outfit, but I'm not pulling often enough to cover a diesel. My current F250 is getting tired. Not bad for costs - $1300 in repairs over the last 2 1/2 years ain't bad, but after fixing this problem 7 times it may be time to change. I'm a knot head though - I like a standard transmission, just like I like manual hubs: When I shift or lock them in, I know they're in. Thanks for your input!
How are the clutches in later F350s?
Old Dec 17, 2013 | 12:53 AM
IDIDieselJohn's Avatar
IDIDieselJohn
Also staying in gear, and on the clutch sitting at a red light also adds alot of unnecessary wear to clutch components.
Old Dec 17, 2013 | 11:56 AM
Nothing Special's Avatar
Nothing Special
I'm not sure what your 2nd gear ratio is, and you don't give your axle ratio or tire size. But a quick look tells me that a wide ratio ZF5 behind a gas engine has a 2nd gear ratio of 2.94:1 (I'm sure other's know better and will correct me if I'm wrong). That isn't all that low, so if you have taller gears (like 3.55 or numerically lower) and/or taller tires, you might need to slip the clutch quite a bit on 2nd gear starts.
My '85 F-250 has an NP435 with (I think) a 3.34:1 2nd gear. With 3.55 gears and 33" tires it worked fine on easy starts, but I'd smell the clutch if I was trying to get into a small hole in traffic.
Old Dec 19, 2013 | 07:25 AM
blackjack95
i have 3.55 gears and 265 75 16 tires.as far as the slave i kind of thout that dorman made them for ford but maybe not.my zf has the 2.94 2nd
Old Dec 19, 2013 | 12:01 PM
Nothing Special
So your truck in 2nd gear is just a little taller than my '85 F-250 was. I'd think you should be able to make easy starts empty without smelling your clutch, but it wouldn't surprise me if you'd heat it up pretty good making hard starts, or using 2nd gear with a load.
