Overheating
Old Dec 13, 2013 | 07:20 AM
  #31
MPoulson's Avatar
MPoulson
Originally Posted by lemonshindig
Listen, I know the gauge isn't accurate.
But it was designed to be centered when the thermostat opens. It isn't. I'm going to find out what has changed, and fix it.
Leaving the stock gauge all catty-whompus and mounting an autometer electric gauge under the dash doesn't fix the stock gauge.
What overheat light are you talking about?
Is it the "engine warning" or " check gauges" light?
Pretty sure there's a little module that switches on that light.
Also, your colleagues at Ford designed the coolant and oil gauges to read vaguely normal most of the time so as not to alarm us dumb farmers.
Even the fuel gauge has a slosh module so we Neanderthals don't panic when we go round a bend or up a hill.
The stock gauges are not accurate.
No, I didn't use the scientific method to prove my hypotheses.
I have seen Ford oil pressure gauges read dead normal at 140psi. Enough to pump the cam followers up and open all the valves. Whoopsie!!
I don't know how to say "factory gauges suck" in engineer, but it doesn't matter cuz you won't listen to a knuckle dragger like me anyway.
Old Dec 13, 2013 | 08:35 AM
  #32
FORDF250HDXLT's Avatar
FORDF250HDXLT
I would just replace the sender, if I was confident that was the problem.
But the gauge and the idiot light appear to agree with each other, and I'm currently under the assumption that they are fed by different sensors: a variable resistance sender for the gauge, and a switch for the idiot light.
So... the engineer in me needs to figure this out. I'm too stubborn to just write "Electron Magic" in a cloud shape, call it my troubleshooting, and install aftermarket gauges.
No sir. I'll be sitting down with a magnifying glass, a case of my best thinking-man's juice (Busch light), and some wiring diagrams I got off of Google that I will blindly accept as accurate. This system is... elementary.
-Matt
i can save you the trouble there too Matt.
the over temp sensor that triggers the check engine light is located up on the drivers side head.up behind the power steering pump.take a look.you'll see the sensor in clear view with a wire.now,when this sensor triggers the light,then it also peggs the idiot gauge needle.
so if you see the check engine light flickering and it's causing the temp needle to swing up too high,then start by inspecting the wire on this over heat temp sensor and if that checks out,then might be able to test the sensor if you can find out what the proper resistance value is suppose to be,or simply toss it and replace it as that is most likely the issue.
all that said,the oem oil pressure and water temps are unhooked in both of my trucks so as not to waste my glance time when it's time to check the accurate number readings on my autometers.
lmao^.
Old Dec 13, 2013 | 10:02 AM
  #33
hairyboxnoogle's Avatar
hairyboxnoogle
I dont know how many lights there are, but im starting to suspect that there is a light tied in with the gauge that if it reads so many volts, or w/ever the hell it reads, so that if the gauge is hot, it also triggers the check gauges light. BUT im pretty sure there is an independant idiot light that has its own sender that says "Engine temp" or similar. I dont know which is which, but i remember some of what i just explained from wiring in the 7.3 gauges / wiring into my 79. The 89 guage wouldnt work without going through its associated idiot light. The secondayr idiot light is the big plug. My guess is its your temp sender or ground, or combination of the two. Check the connection at the sender, and i would just replace it.
Youre like me it seems, drives me nuts to have gauges and not use them. My eventual plan is to send the water an oil gauges off to isspro and have 1/4 sweep steppers installed. However, in the mean time my factory gauge is plenty accurate for me, and rest assured it does work, and fairly accurately too.
Old Dec 13, 2013 | 03:59 PM
  #34
irhunter's Avatar
irhunter
Originally Posted by hairyboxnoogle
I would check out the champion 3 row aluminum on ebay. Cheap and looks good.Ford 1983 1994 F250 Pickup Truck 3 Row Aluminum Champion Radiator | eBay
I don't think the OP is quite at the point of buying more parts. I would rule out pump issues and do a heat map of the radiator first.
But, Hairy, that looks like a great deal. Do you personally have experience with either the Champion radiator or that Ebay seller? Thanks,
Roy
Old Dec 13, 2013 | 04:59 PM
  #35
FORDF250HDXLT
oh yeah that's it.not "check engine" my bad.(iv not seen that one light up but only once i think.tossed that for a real sender now too in the f250.)
Old Dec 13, 2013 | 09:31 PM
  #36
hairyboxnoogle
Roy
I dont, but seems there have been quite a few guys on here and OBN that have em and like em. Ive heard of one bad story, started leakin after a year or so and they sent him a new one. Im definately buying one for mine here in the near future.
Old Dec 14, 2013 | 01:44 AM
  #37
lemonshindig's Avatar
lemonshindig
That champion radiator won't fit my core support, I have the 15x37 non-AC radiator.
But if I were going to replace it, I'd be going with the copper/brass aftermarket by Spectra Premium. $300 at autozone.com right now with their 20% off sale.
-Matt
Old Dec 14, 2013 | 08:10 AM
  #38
irhunter's Avatar
irhunter
Thanks. I'll keep it in mind when I need one.
Roy
67F250RET
26
Aug 15, 2013 11:59 PM
N7ghtwolf
1997 - 2003 F150
33
Jan 5, 2011 09:07 PM
Sheemie
Nov 30, 2004 11:30 AM
Sheemie
Nov 30, 2004 07:10 AM
fseriespower
Aug 27, 2003 11:58 PM
