My cousin has a '99 F250 Super Duty. Every now & then he gets in it and it won't start. He says he has gauges/instruments and can here a relay(?) click. Not the solenoid, but a relay(?). He got down on all 4's & jumped the starter with a screw driver. Got home, shut it off, and it wouldn't start again. I checked for TSB's & recalls but found nothing.
Any help on this one? He can't be the only one with this problem!
Thanks in advance,
jonny
I'll check for 12v. at the "s" terminal on the solenoid in the "start" position If I have 12v. then the solenoid's bad. Can solenoids be intermittant? It was very humid today...could that effect the solenoid?
have same problem starter intermitent starts when cold 4 or 5 times then nothing changed relay,started then nothing.changed starter with new oem ford starter a few times then just a relay clich. help
sorry it's auto and no neutral dosen;t help. the dealer thinfs it the starter but I find it hard to believe that the oem starter we put in worked for 5 trys then nothing again.thanks for your reply tho. rick
