EGT and NOX Sensor...KISS IT PLEASE
#31
Another thing. On my 2015 there is a sensor aft of the rear axle right at the top of the exhaust pipe. This is new.
It irritates me to find it because I wanted to install the AFE DPF-back pipe I had on my 2011 truck. I started to gear up to do the install and saw that dang sensor and proceeded to give the pipe away..........
Hope that helps
#32
Our check engine light came on and the code was P2209, the NOx sensor. Went to AutoZone and had them run a diagnostic. We have a 2012 Ford F350 DRW with 70,000 miles on it. After a day, the check engine light went off. We are towing a 16,000lb Fifth Wheel and are out of town.
The question is, do we take it in or wait until the light comes on again?
Thanks for your help.
Nancy A.
Nancy A.
#33
#34
Since the light is off, could it have reset itself?
Thanks,
Nancy A.
#35
#37
Don't be surprised if the CEL comes back. My '11 had the same issue about a year ago, CEL would come on then the next day be off and wouldn't return for several weeks or so. Performed all the factory pinpoint tests and everything checked out. Ended up swapping it before hitting the road for several months of racing and haven't had an issue since.
#38
Nancy A.
#39
I know this is an older thread, but one thing I noticed was people buying a spare EGT and Nox sensor. I have a spare EGT because all four positions use the same pn, but when I looked into buying a spare Nox sensor, the dealership pulled up the diagram and showed me different pn's for the different locations...and they weren't particularly cheap either.
#41
I've replaced both EGT and NOx sensors and no programming need for either, simply R&R. I soak the threads with PB Blaster for an hour or so before attempting to remove and they've always come right out.
#42
#43
#44
#45
