1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Rats under hood
Old 12-10-2013, 02:36 PM
bassman212's Avatar
bassman212
bassman212 is offline
Rats under hood
I have a 2006 F-250 Super Duty 4X4 with 5.4 3V Triton engine. I had some rats build a nest in my engine compartment. The engine ran rough after cleaning the nest out and I found a vacuum line ate in two. I replaced the line and now I get a check gauges message and my coolant gauge never moves. I found a short piece of plastic wiring loom in their nest and think that they ate the wire into going to the water sensor.
My problem is I can't locate the water sensor or a loose wire anywhere. If I had the location, it would give me an idea where the wire would be routed.
Thanks
Old 12-10-2013, 02:55 PM
r2millers's Avatar
r2millers
r2millers is offline
Thanks
This picture in this FTE post should be the same location as this modular V-10 location.
https://www.ford-trucks.com/forums/1...in-my-v10.html
Old 12-10-2013, 03:38 PM
bassman212's Avatar
bassman212
Looks totally different and I don't see any sensors in that area. Ford states that it is a sensor in metal and not the water jacket.
Old 12-10-2013, 03:59 PM
bassman212's Avatar
bassman212
P1289 Ford Description
The Cylinder Head Temperature (CHT) Sensor is mounted into the wall of the cylinder head and is not connected to any coolant passages. The CHT sends a signal to the Powertrain Control Module (PCM) indicating the cylinder head temperature. If the temperature exceeds 126°C (-258°F), the PCM disables four fuel injectors at a time. The PCM will alternate which four injectors are disabled every 32 engine cycles. The four cylinders that are not being fuel injected act as air pumps to aid in cooling the engine. If the temperature exceeds 154 °C (310°F), the PCM disables all of the fuel injectors until the engine temperature drops below 154°C (310°F).
Does this mean that I will have to pull the intake to get to it?
Old 12-11-2013, 04:34 PM
bassman212's Avatar
bassman212
Still waiting for any help. I hate to start taking the engine apart before knowing.
Old 12-11-2013, 06:52 PM
05F250DSL's Avatar
05F250DSL
05F250DSL is offline
Go here http://m.autozone.com/autozone-mobil...=Temp%20sensor
That is what it is showing for your truck but it does not give a location
Old 12-11-2013, 07:00 PM
redford's Avatar
redford
redford is offline
Received 1,610 Likes on 941 Posts
You may have to blow it up, but this should help.
Old 12-11-2013, 07:10 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
If memory is correct , The CHT sensor is under the intake ......
RRPAYETTE
2004 - 2008 F150
15
03-19-2023 01:38 PM
EVERY DETAIL
3.8 & 4.2L V6
10-26-2014 01:11 PM
jmcs23
1997-2006 Expedition & Navigator
10-21-2014 01:02 PM
gforce5
1997 - 2003 F150
04-15-2007 08:59 PM
amish_dan
1983 - 2012 Ranger & B-Series
10-03-2005 10:55 PM
Quick Reply: Rats under hood
