48ford f1
Old 12-09-2013, 08:47 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,468 Likes on 1,408 Posts
Originally Posted by train2
Hi,its been awhile.I have a 1948 ford f1 226 motor 4 spd trans short bed 5 lug bolt pattern.I am having problems with serial numbers,they don't match Glove box number 87HY80400 8HC Engine # 7HA6015B Trans #7HY80400 Frame #87HY80400 rear end tag #4EV-AA1 7ED 75-9 718A any help telling me what I have would be great, Thanks
My 2c is you have all the original engine and transmission. 7HA is the correct engine code for a 6 cylinder truck. The number on the trans is a partial vin that matches your frame. The one thing that stands out to me is the rear end tag. The original Dana rear didn't have a tag, and your's looks like one from a later 9" Ford. I'm guessing where you have 75, it's next to a bolt and right by it probably says 2., meaning 2.75 ratio.
Old 12-09-2013, 08:55 PM
train2's Avatar
train2
train2 is offline
Ok thanks,I was hoping this was original engine,you are correct about rear tag ford 9 out of econoline van,I am looking to keep this truck Thank You for all replies
Old 12-09-2013, 09:11 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Originally Posted by 48ATOY
I have a 48 F1 with Y vin code
226 4sp f1 stake with overload springs?
5 1/2 lug
JOE
Hard to believe that was almost 10 years ago?!
https://www.ford-trucks.com/forums/2...tion-87hy.html
Old 12-10-2013, 04:29 AM
dmack91's Avatar
dmack91
dmack91 is offline
I thought the econoline rear axles were several inches wider than the F100 versions? If so, is it going to cause you a problem with the width?
Old 12-10-2013, 06:27 AM
train2's Avatar
train2
train2 is offline
No this one fit right on original spring perches,plenty of room in fenders for wider tires,bolt right in
Old 12-10-2013, 01:08 PM
dmack91's Avatar
dmack91
dmack91 is offline
That sounds great. I looked it up and it looks like in the mid-70's they increased the width to near 70", so I guess the earlier ones must have been the same as the F100's.
Dixon1948
07-20-2019 10:00 PM
Ironbeard
04-29-2019 10:49 AM
craignmullis
12-03-2013 01:57 PM
mozart
17
01-31-2010 06:20 PM
dixon18
03-02-2004 12:08 PM
Quick Reply: 48ford f1
