Wood bed alternative?
Old Dec 8, 2013 | 07:13 PM
ldouble619's Avatar
ldouble619
I plan on using my f100 as a truck... hauling crap, parts, scrap, lumber...etc. And my truck sits outside.
What are some alternatives to wooden bed kit?
Thanks
Old Dec 8, 2013 | 07:19 PM
Doc's Avatar
Doc
A big piece of treated marine plywood comes to mind.
Old Dec 8, 2013 | 07:29 PM
my 66's Avatar
my 66
bed
How about the floor out of a newer pickup?
Old Dec 8, 2013 | 08:19 PM
Chris 56 f6's Avatar
Chris 56 f6
You could still use a wood bed but use a wood like teak or ipe both are very hard and hold up out side the best . If you are better with working with steel you could use flat sheets of steel and weld it to the sides
http://www.advantagelumber.com/mobile/decking2.htm
Old Dec 8, 2013 | 08:34 PM
GB SISSON's Avatar
GB SISSON
Ipa is very hard to work, and teak is about 20.00 bf right now. I have 2 flatbeds that I built from steel, but are decked with 2 layers of 3/4" pressure treated plywood. It's made for below or at grade construction. Not sure if marine plywood is available in treated. It is normally made from high grade veneers, with no voids, and a marine grade glue. I vote for the pressure treated plywood from your local lumberyard, and way cheaper. Both trucks stay outside in the Pacific Northwest horrible weather. My .02
Old Dec 8, 2013 | 08:38 PM
ldouble619's Avatar
ldouble619
I'm leaning towards throwing in a sheet of 3/4" treated plywood.
Old Dec 8, 2013 | 11:21 PM
Horizonblue's Avatar
Horizonblue
I have not done mine yet, but I am considering using composite deck wood. I think there are some issues with shrinkage and contraction, but maybe some other members have more info on this.
Old Dec 9, 2013 | 12:46 AM
das54's Avatar
das54
I was thinking about 2x6 T&G pressure treated but my brother tells me the pressure treated is very corrosive and I'm sure no matter what you paint the steel parts with that contact the wood the paint will rub off.
Old Dec 9, 2013 | 12:50 AM
Mervy49's Avatar
Mervy49
I have been thinking about putting in a layer of 3/4" pressure treated plywood and 16 gauge aluminum with diamond plated pattern over that.
Old Dec 9, 2013 | 06:02 AM
topmoo's Avatar
topmoo
Use Accoya, wood that won't rot in our lifetimes. Check it out: Accoya Uses Chemistry Trick To Detoxify Exterior Wood Treatment Process | TechCrunch
Old Dec 9, 2013 | 07:44 AM
jvmcc's Avatar
jvmcc
When I first got my truck the bed wood was just about gone. I ripped some 5/8" CDX and installed it using the original metal bed strips which were still usable, though much rusted. I applied linseed oil thinned with mineral spirits to the ripped plywood before assembly. Over the years, whenever I washed it, I would recoat my plywood bed wood with fresh coats of oil. I cut and hauled firewood for several years, then moved to the northeast from California where I used it as a daily driver and work truck for about ten years. In all that time, it was never garaged or treated gently. Only recently have I started to restore the truck. When I removed that plywood bed wood, I found that it was still in very good condition...it could easily have lasted another ten years. Caveat: I did this plywood bed over thirty years ago. The CDX plywood available at that time was Douglas Fir and was a much better material than the CDX that one would commonly find nowadays. And, except for rabbetting shallow channels in the wood for the bed strips, the labor was about the same as if I'd used solid wood. This is all a long-winded way of saying that I've used plywood with great success
Old Dec 9, 2013 | 07:57 AM
oldmerc's Avatar
oldmerc
oldmerc
Pressure treated lumber and plywood is extremly corrosive to anything ecxept stainless steel . I would suggest white oak boards and just paint them like the factory did . I know the originals were pine but depending on where you live and how handy you are with a table saw the oak may be better value .
Old Dec 9, 2013 | 08:47 AM
WALFORD'S 56's Avatar
WALFORD'S 56
The sheet of plywood is usually the cheapest, and easiest method of most truck guys who use their trucks, or a plate of steel . Have seen both.
On the 53 my wife used for mulch we installed plastic sheeting 4 x 6 in the bed and along the sides and even over the tailgate. They clean up nice with a hose, and you can even lay them against the rear window area to keep mulch,etc from touching the cab....cheap but effective
Old Dec 9, 2013 | 08:58 AM
Chris 56 f6
New treated lumber and old treated lumber
Treated lumber is not the same as it was two years ago it is some very ccorrosive stuff read up on it here.
http://www.fortatkinsonwi.net/depart...dLumberNew.pdf
It will eat through aluminum
Old Dec 9, 2013 | 08:59 AM
bigwin56f100's Avatar
bigwin56f100
Good info, I didn't know that
