12v variable speed controller for a motor
Old Dec 9, 2013 | 12:27 PM
Diesel_Brad's Avatar
Diesel_Brad
Guys, I got myself in a bit of a jam.
My neighbor goes to Florida every winter and leaves me to plow/salt his driveway in case of emergency(******* hill)
He bought me a salt spreader made by a welding shop for my Ranger. It is a little thing. Holds about 200lbs of salt.
The guy who makes them uses a 12 Dayton electric motor on them. the problem is it is a 2350rpm motor. I want to slow it dow to keep the salt ON the driveway instead off off in the woods.
I am looking for something to change the speed. I thought I had it figured out, I bout a used controller off ebay for a salt spreader but that ended up being no good. New ones are 300+. I really can't justify spending that kind of $$ to do his and my driveway
Is there anything I can get my hands on to vary the speed? I went to radio shack and they were no help
PLEASE HELP ASAP
Motor specifics
12v PM DC
HP: 1/35
RPM 2350
F.L. 3.70 amps
Old Dec 9, 2013 | 01:09 PM
UNTAMND's Avatar
UNTAMND
Make sure your deflector flaps are angled correctly. My brigs and stratton powered sander on my c&c truck is one speed (unless I mess with run screw) and I found a good happy medium between conveyor speed (Geared to the spinner speed) and ended up changing the angle of the metal flaps to direct sand/salt down.
How about a scooter motor controller or one of those kids 12v ride on cars.
Being only 4 amps can you get a big ballast resistor and have a couple of them for different speeds.
Old Dec 9, 2013 | 02:23 PM
Diesel_Brad
yeah, I have a old bed mat as a deflector
You are WAY over my head with a ballast
Old Dec 9, 2013 | 03:40 PM
Diesel_Brad
Anyone know if this would work?
http://www.ebay.com/itm/12V-40V-10A-DC-Pulse-Width-Modulation-PWM-Motor-Speed-Control-Switch-Governor-/360606529020?_trksid=p2054897.l4275
Old Dec 9, 2013 | 03:44 PM
UNTAMND's Avatar
UNTAMND
Not enough people frequent this section I don't think.
Try posting in the truck section and see if the guys don't chime in.
Someone must be an electronics guy to be able to tell you how big of a resistor to use to make a certain amp draw from 12v down to 10v. THats all you need to do.
I'll search for a calculator online also.
Basically RadioShack or some other electronics component store locally should have something. You just need something that will handle 4-5 amps. (May need up to 6amps due to less voltage using more amps)
Old Dec 9, 2013 | 03:48 PM
UNTAMND's Avatar
UNTAMND
You're on the right track but it doesn't go lower than 12v. Need more specs than what's listed. Is that 12 to 40v input and it varies pw from .01-400 watts or is it 40v input and it varies it down to 12v and .01-400 watts.... I don't know enough about it to say yes or no.
Old Dec 9, 2013 | 03:55 PM
UNTAMND's Avatar
UNTAMND
Ask a parts store about the ballast resistor used on the older Chrysler ignition system. They reduced to like 9v. Hopefully there's an amp rating on it. I mount them to a piece of aluminum to help heat sink it.
Or ask them about a ballast resister for the 6v car conversion. When people used a 12v battery and starter on a car originally 6v.
Old Dec 9, 2013 | 07:32 PM
Franklin2's Avatar
Franklin2
I can tell you a resistor will not work very well. It will have to be very large, and as the current goes up on the motor(salt hits it) it will slow down.
If he wants to go half speed, that would be 6v. That means he would be dropping 6v on the resistor to get 6v on the motor. 6v x 3.7a =22watts. A 22 watt resistor is pretty big, and very hard to find and expensive, and it will not work very well. I tried the same thing on a 6v wiper motor on the 53 f100 and that's how I found out about the speeding up and slowing down thing.
Let me look around a little bit.
Old Dec 9, 2013 | 07:39 PM
Franklin2's Avatar
Franklin2
Originally Posted by Diesel_Brad
I am thinking that controller would work. I believe the 12v to 40v is the input voltage. This controller chops the voltage up. If you put 12v on it, then it would chop the voltage up, it will always be 12v, but if it chops it 50%, then it will only run half speed. Does that make sense? That's how the fuel injectors work on a fuel injected engine. At idle they just blip the injectors on for a very short time, and as the engine needs more fuel, they turn the injectors on longer and longer. That's what they mean by PWM in the ad, which is pulse width modulation.
Old Dec 9, 2013 | 08:30 PM
UNTAMND's Avatar
UNTAMND
With pwm you don't lose as much torque output. You will lose some, but like was said it basically turns it on and off really fast to vary the speed.
I was just concerned with the input voltage.
Old Dec 9, 2013 | 08:43 PM
JWC 3's Avatar
JWC 3
How bout using 2 , 6 volt deep cycle batteries ( not wired in series ) to run it . Good cables , heavy 6 volt system ? Stupid thought maybe , but a thought !
Old Dec 10, 2013 | 06:23 AM
projectSHO89's Avatar
projectSHO89
Hmmm...
Here's an idea. How about a resistor pack/speed sitch for the HVAC blower?
Old Dec 10, 2013 | 08:32 AM
UNTAMND's Avatar
UNTAMND
Originally Posted by projectSHO89
Hmmm...
Brilliant
I thought about one/two ballast resistors, but using a heater blower resistor pack should work. It may need to be cooled. That's why it's in line with the air path to help cool it I think.
Old Dec 10, 2013 | 09:28 AM
dixie460's Avatar
dixie460
Just went and looked at the PWM controller on eBay. From the info I can find on it, it will work fine with your salt spreader motor. Not sure on the quality of the components though... for less than $6 it's gotta be Chinese lol.
Also, the blower resistor idea is fine too as long as that blower motor is rated equal to or more than the FLA of the spreader motor. I'm pretty sure it is but I doubt it's published anywhere. A small 12V electric fan can cool the resistor pack.
Old Dec 10, 2013 | 02:57 PM
Franklin2's Avatar
Franklin2
Hmmm...
Same problem, the motor speed will vary wildly depending on the load of the motor.
From the previous example, full load on the motor is 3.7a. If we wanted to run half speed at 6v, we would need to drop 6v across the resistor. 6v divided by 3.7a equals a 1.62 ohm resistor would be needed, when the motor was at full load. Lets put less salt on it, so the motor is now only drawing 1.85amps. We still have the same 1.62 ohm resistor, but now only 1.85 amps is flowing through it. 1.85a times 1.62 ohms equals 2.997 volts. At half the amperage draw, we are now only dropping 3v across the resistor, which means the motor now has 9v on it instead of 6v.
This is not a problem if the load remains fairly constant. But I am thinking a salt spreader is going to be a problem. I am sure this motor will draw more than 3.7a if a chunk of salt got hung up in it. If the current doubled, the motor would have a tendency to stall out, the resistor would be dropping all the voltage to it.
