LMC TRUCK replacement Dash Covers, thoughts?
#91
I get really bad vibes from Just Dashes. They told me the absolute wrong price, and that fits with some things I've read on the internet about them. But Dashes Direct called me back to say that they were wrong when they said our original dashes have metal bases - they are plastic. One was wrong on a very, VERY major point and I didn't find out until I called back. The other was wrong on a trivial point that made no difference at all, but called me back to sort it out.
Or, let's look at it another way: The guy at JD wasn't competent to do his job of quoting prices, and the guy at DD is so meticulous that he fretted over a statement that had no bearing. Either way I get much better vibes from DD than JD.
#93
#94
I'm told the SEM paint covers black quite well. Having said that, I would order white if it is available. But black might look very good in a blue truck.
#95
Hmmm. I was thinking, When I had my 1948 F-5, I tried ALL available cab corner patch panels. NONE fit.
So I made a set of dies and press them myself, an exact copy of the original. also make the fender patches....
So back to my thinking, Since we all suffer speaker hole-itis is why not make a "patch panel"
Example, cut out a square (or rectangular) hole to remove the original speaker area, insert a new-replacement.
Now, My old graphics professor always stated, "if you cant match the color exactly, make if different on purpose"
Figure a drop in insert, sitting lower (like a new dash's "utility pocket") with a lip about a quarter inch higher so it sits inside. Just like how your kitchen sink sits on the counter.
Obviously a unit with a stepped lip would be best, just cut the hole and stick it down.
Good luck at your end.
#99
Just to throw this into the conversation, My dash cover had the usual hole where the speaker is. I just repainted it and added this LMC Dash Protector. I've had it 3 years and it's not faded and looks really nice.
Truck Parts and Truck Accessories
#100
#101
Sorry for the delay in getting pictures. Here you go. The dash seems nice, however, I noticed a tear in one of the corners of the dash. I have a call into NPD about this and hopefully they will resolve the issue.
Box:
Packaged Dash:
It is a bit flimsy but the original dash was a bit flimsy too.
Eric
Box:
Packaged Dash:
Eric
#103
#104
NPD has them in black or white - I went with black as I am changing the interior to my truck to black (thread titled "Piney's Rebuild"). Including the freight I paid $453.50.
As my previous post said I noticed a tear/nick in one of the corners of the dash. NPD came through and are picking it up and sending me a new one. Good customer service.
#105
I just talked with Dave at SEM Products and he said 2 or 3 light coats of their paint will hide either the black or the white and give the same color in the end. The coats should be light to make sure they don't run and hide the grain, and wait about 15 minutes between coats to allow them to flash.
Given that I'm thinking I'll go with JBG's black unit, although I'm not quite decided yet. Let's hear some more thoughts on the quality. And I want to look at it on a big screen. Plus, maybe get pics from DD.
