Few questions regarding the 4x4 operation. First, the hop. I'm a little confused by what I've read here... This morning, for example, I was in 4x4 on snow and ice and it still hopped a bit making a tighter turn... Is that normal?
Next, is there a max speed I should worry about shifting into or out of 4x4 mode?
Everything is running great, and I want to keep it that way.
Yeah... Low speed tight turns does produce the hop. Assuming thats normal then. Thanks for the speed thoughts, too. It hasnt been a problem doing that... I just didnt want to create one by doing that.
My shortbed does not hop even on just rain; definitely not on snow. It does hop/bind on low speed tight turns when parking so now I park in 2x4.
No idea about max speed. I can switch easily at city road speeds.
Why are you using 4x4 in the rain? or on dry pavement? using it in anything but snow or off road eats up tires and u-joints and is a lot of stress on the t-case
The "hop" your experiencing is the ujoints in your knuckles on the front axle, as the ujoint goes through one revolution during a tight turn it speeds up and slows down in two cycles so as your driving the turn the axle will torque up and release as the wheels turn, also to add to this the front axle is turn a larger radius then the rear axle requiring it to travel a longer distance further torquing up your driveline. Your front and/or rear wheels actually have to slip to compensate for this.
I find it amazing 4x4 trucks are still built like this. The ujoints in the front axle are okay but the transfer case should have a differential built into it to compensate for the offset in speeds.
Never tried on dry. Tried on rain because I wanted to try the 4x4 before winter and was lacking in mud.
Today I tried 2x4 without traction control in snow. Not gonna try that again; torque = instant slip
Ok there are alot of things wrong with this... First off all 4x4 trucks weather solid front axle or cv shaft up front will hop on dry pavement. This is not a problem with just solid axle u-joint trucks.
Second if a t-case had a open differential. It would act like a open rear end sending power to the wheels with the least traction. Leavening you with only front or rear wheel drive.
Finally KEEP YOUR TRUCK OUT OF 4x4 UNLESS IT IS REALLY NEEDED!!! Rain, dry dirt, grass, or gravel are not a reason to use 4x4. If you don't know when to pull the lever and lock the hubs you should have bought a 1/2 ton Chevy with the auto 4x4 option
4x4 in rain or even dry pavement wont hurt a thing so long as you don't turn. think about all the diesel guy's running the 1/4 mile track in 4 high.
It will probably burn the rubber a bit faster on dry. Not sure by how much(5%?) and it really is useless unless you need to fast eject from every red light.
I like to use it in the rain. I often spin in 2x4 from stoplights and redlights from rain and the accumulation of car fluids in those places making the road slick.
With the ice and snow in the northeast this week, I needed to kick in the 4x4 just to get out of my driveway. It was all ice, and without the 4x4, I was unable get forward traction on a slight incline. On the return trip, I was in four-wheel, but part of the driveway hadn't been affected by the ice, and the tires caught it on a tight turn as I was navigating to get into the garage. The rear wheels were still on the ice. That is where the hop occurred, prompting this thread.
