Sponsored by: Real Truck
4x4 basics, please
Old Dec 12, 2013 | 07:42 AM
mecdac's Avatar
mecdac
Originally Posted by A/Ox4
Ford recommends switching from 2x4 to 4x4HI above 5mph, and below 55mph.
To switch from 4x4HI to 4x4LO you must stop, but place the vehicle in neutral and have your foot on the brake.
According to Ford you dont have to drive in reverse to disengage the system, but they do acknowledge that is helps.
I have to go to Neutral to come out of 4X4 LOW also.
Old Dec 12, 2013 | 10:16 AM
offroadnt's Avatar
offroadnt
Originally Posted by Allstar recovory
Ok there are alot of things wrong with this... First off all 4x4 trucks weather solid front axle or cv shaft up front will hop on dry pavement. This is not a problem with just solid axle u-joint trucks.
Second if a t-case had a open differential. It would act like a open rear end sending power to the wheels with the least traction. Leavening you with only front or rear wheel drive.
Finally KEEP YOUR TRUCK OUT OF 4x4 UNLESS IT IS REALLY NEEDED!!! Rain, dry dirt, grass, or gravel are not a reason to use 4x4. If you don't know when to pull the lever and lock the hubs you should have bought a 1/2 ton Chevy with the auto 4x4 option
Actually the ujoint style is worse and it's irritating. Second I live and work out on a farm/ranch. I operate in conditions that can range from hardtop to mud bog within a couple feet, I'd be replacing **** components monthly if I operated the way you suggest...
That being said the ujoint style is also simpler and tougher then other style and I hope it lasts well. I do know what your saying though.
I didn't take the time to describe the differential they should use. My favorite is the Gleason differential, second is the Detroit locker. In both cases these units would allow for the differences in speed as well as provide for positive four wheel drive traction. I just think after almost a hundred years of four wheel drive vehicles this technology would incorporated into pickups by now. How does Subaru's 4x4 technology work for instance?
Since when is s h i f t a swear word?????
Old Dec 12, 2013 | 11:02 AM
BCM's Avatar
BCM
When you miss the 'f'.
Old Dec 12, 2013 | 11:49 AM
Fastfwd's Avatar
Fastfwd
Last time I checked it was viscous coupling. Audis used torsen. My MDX is all electronic. I think that probably those would not work reliably on big torque and big weight vehicles. Seems like viscous already works poorly on older Superdutys for the rear diff.
Too bad. Auto AWD is very convenient on changing roads. Right now all smaller roads here are very slick ice but all major roads are dry asphalt.... Mostly
Old Dec 12, 2013 | 12:57 PM
troverman's Avatar
troverman
The Ford manual recommends many things which may not be necessary. For example, on Super Duty's with manual hubs / manual 4x4 shift, they recommend shifting in and out of 4x4 at speeds less than 5mph. In fact, with the hubs already locked in, and the rear wheels not spinning, one can shift in and out of 4x4 High at virtually any speed. To avoid damaging anything, it is best to do this with the front wheels turned straight and your foot off the throttle. To shift into Low Range, the transmission should be in neutral and the vehicle speed should be 5 mph or less. This is the same procedure for probably any vehicle with low, electric or manual shift, or permanent 4x4 such as my Range Rover. The reason is the reduction gear, of course...you cannot 'shift on the fly' into low or the sudden reduction in the drivetrain would most likely cause damage to any number of torque-stressed components, or perhaps over-rev the engine, or cause loss of vehicle control, or all of the above.
Another 4x4 basic knowledge (as somewhat already covered here) is knowing that these Super Duty trucks have a Part-Time system. The part-time system only means that there is no method of varying speed between the axles. If we all only drove in a straight line, a part-time 4x4 is no worse for wear than a full time 4x4. You can engage your truck's 4x4 Hi or Low at any time on dry pavement without fear of damage so long as you don't turn. Of course, that is not practical, so 'Part Time' refers to only engaging 4x4 when driving on low traction surfaces, such as snow, ice, or off-road.
A brief explanation of why a part-time system cannot be used all the time, but a full-time or permanent system can:
When a vehicle steers, the wheel on the outside of the turning radius (the corner you are going around) must actually spin more times than the wheel on the inside of the turning radius. This is because the outside wheel is covering more distance. To allow this to happen, vehicle manufacturers use a differential (the pumpkin hanging down on the front and rear axles) However, when the same vehicle is steering around this same corner, there is also a difference in speed between the front and rear axles. This is because the rear wheels do not actually steer, so they 'follow' the front wheels, but not in exactly the same path. Notice when you drive your vehicle in fresh snow on a corner and then look behind you, there are not just two tire tracks...there are four. This is all totally fine on a two-wheel drive vehicle...the front and rear axles are not connected, and the axle differential will handle any difference in speed between inner / outer wheels. The problem is when 4x4 is engaged on a part-time system, the transfer case spins the drive shaft to the front and rear axles at exactly the same speed, at all times. This forces the front and rear wheels to turn at exactly the same speed. While the front and rear axle differentials will compensate for wheel speed variations on their respective axles, they cannot compensate for the fact that the rear wheels together are spinning slightly slower or faster than the front wheels, together, during a turn. Thus, by engaging 4x4 on a part-time system, you are locking the axles together. When used on a lower-traction surface, such as mud, sand, dirt, snow, etc...there is no problem...the front or rear wheels actually slip a little on their own to compensate for differing axle speeds. However, on dry pavement or other tractive surface, the wheels cannot easily slip...resulting in "hop" and driveline stress.
Now consider a vehicle with 'full-time' or 'permanent' 4x4: a third differential is included into the system, typically installed in the transfer case (center differential). This allows the front and rear driveshaft speed to vary between the axles...and the result is very smooth 4x4 operation that will never hop, even on the most high-traction surface.
Keep in mind, however, that any normal, open differential (front, center, or rear) is a double-edged sword. It makes for smooth operation, but by its very design it will always send power to the path of least resistance. This is fine for a high-traction surface, but now consider this scenario: your truck is parked on a street, facing uphill. You are in 2WD, and water running down the hill in the gutter has frozen. Your right wheels are, in fact, setting completely on ice while the left wheels are on dry pavement. You try to pull away, but only the right rear wheel spins! You go nowhere. So you engage 4x4 and try to pull away. Now, both right-side wheels in the gutter on shiny ice spin, but both left side wheels on pavement don't turn at all...and your truck goes nowhere. The reason is that power flowing through an open differential always goes to the path of least resistance...in this case it is easier for the diff to spin the wheel(s) on ice than to shove the truck forward against the traction of the dry pavement.
The vehicle with full-time 4x4 parked just up the street from you does no better. In fact, he does even worse. In his case, only his right front wheel is on ice, and the other three wheels are on dry pavement. It is true his vehicle is always in 4x4, but now there are more differentials in the equation. In this case, the center diff sends power to the path of least resistance, which is the front axle; the front axle diff then sends the power to continue along the path of least resistance which is the front right wheel, which spins uselessly on ice. So, despite being in 4x4, this vehicle can actually only spin one tire.
Of course, most vehicles with full-time or permanent 4x4 include a solution to this problem, with some sort of limited-slip or locker device on the center differential. In terms of traction, this now puts them on equals with a stock "part-time" system. Why are vehicles still made with part-time systems? Easy, a transfer case with a center diff and some additional type of locker or anti-slip mechanism costs considerably more than a simple part-time system. Additionally, a part-time system is lighter weight, and has the advantage of improving fuel economy when 4x4 is not engaged. It is also interesting to note that a vehicle with full-time / permanent 4x4 with a locked center differential will also suffer the same 'hop' and driveline stress as a part-time 4x4 vehicle with the front axle engaged.
Finally, back to the icy street scenario: at the very least, traction control will get the truck moving with the right-side wheels spinning. The ABS detects the right wheel spinning, but not the left. The ABS then pulses the brake rapidly on and off (on the spinning wheel only) which creates resistance, sending pulses of power over to the left wheel with traction. This is usually enough to get a vehicle moving and on to better traction, but the traction control itself cannot be used continuously or it will overheat the brakes and shut down. This is where a locking rear diff, or even better locking front and rear diffs, come in. Some Super Dutys have the factory rear locker...toggle it on, and the rear diff locks together, meaning both wheels are forced to turn at exactly the same speed. In this scenario, our example truck easily drives away. Once again, however, note that locking axle diffs cause even more difficulty with turning than locking transfer cases, due to not allowing any variation in speed between the inner / outer wheels. Very few vehicles offer locking front differentials as factory due to turning being almost impossible. Two vehicles that come to mind include the Jeep Wrangler Rubicon (locking front and rear diffs, part time 4x4) and the Mercedes G-wagen (locking front, center, and rear diffs, permanent 4x4).
Sorry for the long post, hope it is helpful to provide some basic understanding of 4x4 systems and differentials.
Old Dec 12, 2013 | 01:38 PM
troverman's Avatar
troverman
Super Duty's actually have never used a viscous system. I think you are mistaking a "limited slip" rear differential for a viscous system. A viscous coupling basically uses an input and output shaft which extend into a sealed chamber. Each shaft has a series of turbine-like blades on the end of the shaft inside the chamber. The shafts nor blades touch, and the chamber is filled with a silicon-like "viscous" fluid. During normal operation, with very little difference between front and rear axle speed (such as when cornering), the blades shear through the viscous fluid easily, with very little resistance. However, when wheels on either axle begin to slip, that respective input or output shaft begins to shear through the viscous fluid much more quickly than the non-slipping axle blades...the increased friction quickly causes the fluid to become more viscous (due to its properties), thereby 'locking' the axles together. Once the slippage is over, and the axle shafts begin turning at the same speed again, the viscous fluid becomes less viscous and the axles are 'unlocked' once again. Some AWD vehicles (i.e. Lexus RX300) use only a viscous coupling unit as both the center differential and the limited slip; others use both a center differential and a viscous coupling unit (i.e. earlier Range Rovers). In my experience, the viscous coupling units hold up very well for many years. They do not gradually fail, but rather they typically fail 'locked up' meaning you are in locked 4x4 all the time, not good unless you are off road.
Audi does use a Torsen based center differential, and it is very effective and reliable. However, the Torsen system has limitations by design which can effectively prevent drive to any wheel if one wheel is off the ground completely, since resistance, however minor (e.g. ice), will cause it to function properly. This can be overcome through the use of traction control (very effective at making a Torsen work with a wheel in the air) but is the primary reason why Torsen center diffs are typically not used on off-road vehicles (except the gen III Range Rover). However, note that this type of diff is used very effectively in an axle differential (e.g. the front diff on the Ford Raptor)
Another common 4x4 system is the 'electronic locking multiplate clutch system' which you Acura may have some version of. Effective and smooth, yes, but could fail. It is easy to criticize the Super Duty's basic part-time system, but it is a very durable system with little to go wrong with it. I do completely agree with you about how convenient AWD / full-time / permanent 4x4 is on changing road surface conditions, though.
Old Dec 12, 2013 | 01:45 PM
Fastfwd's Avatar
Fastfwd
[QUOTE=troverman;13836276]Super Duty's actually have never used a viscous system. I think you are mistaking a "limited slip" rear differential for a viscous /QUOTE]
Wow. You know your stuff
So what is limited slip made from?
Old Dec 12, 2013 | 02:00 PM
offroadnt's Avatar
offroadnt
Nice Troverman . That covers it very well, here's a few things some of you may have observed with spinning wheels.
If the vehicle is not moving and only one wheel is spinning it will be spinning at twice the speed of normal. Why? Because as the crown gear turns it turns the carrier whitch carries the spider gears around at the same speed, but as the spider gears are being carried around they are forced to spin on the spider because they are engaged in the side gear that's linked to the axle that isn't turning because it is tied to the wheel with traction. These gears are also engaged with the side gear, axle and wheel that are spinning. The result? The spinning wheel turns exactly twice as fast. If you have a vehicle with an open differential in the transfer case also and only one wheel spins of four, guess what? That wheel spins four times as fast! Anyone that has been around tandem semis may have observed this, it's pretty wicked. Even more extreme is tri drive semis, this factor is increased to eight times. WARNING!!!!! If your playing or experimenting with this only run it for a very short period of time and light load. High speed spinning with one wheel is very hard on differentials. EXTREMLY IMPORTANT!!!! Never engage diff locks or transfer cases when wheels or axles are spinning, I've seen the results of this, one 27,000 lb rated differential carrier literally blown up into a thousand peices because of this. It must have been one big bang... If all wheels and axles are turning the same speed this is no problem and I do it all the time.
troverman's Avatar
troverman
Ford Limited Slip rear ends use clutches which when one wheel begins to slip, force a set amount of the torque over to the other side which presumable has more traction. The downsides of these are that the clutches wear out, and when they do, the differential becomes a normal, open diff with no control of side-side wheel slip. Additionally, the clutches cannot direct very much torque away from the side which is slipping; sometimes as low as 15%...depends on how aggressive the clutches are set from the factory. On the upside, they are fully automatic, better than nothing, and can be rebuilt when they fail.
Old Dec 12, 2013 | 02:13 PM
troverman's Avatar
troverman
Good point...and this is another reason why traction control should be used sparingly...you've got that wheel spinning very fast and then it is suddenly braked in a pulsating manner, which not only repeatedly shocks that axle half shaft, but also the other side when it suddenly receives torque, and the spider gears as well. Traction control typically 'hits' harder and harder as you apply more and more throttle...this is one reason why many vehicles so equipped also limit throttle input during TC operation.
The Super Duty system seems to be more abrupt than some systems, but on the other hand, the rear driveline components are very strong on this vehicle. When Land Rover installed traction control on its vehicles (rear wheels in '93 and then all four starting in '99) they were forced to upgrade the axle half shafts and differentials to be able to handle the torque shock loads which were generated. Those early Rovers wouldn't limit engine power during TC events, though, and this made their system much more effective off-road than today's systems. Still, selectable lockers are superior by far, assuming the user knows proper operation.
Old Dec 12, 2013 | 08:33 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Ive never been in a situation where I thought I had insignificant traction and required 4x4 yet thought it was safe to travel at 70mph or higher.
But thats just me.
Sent from my Galaxy S4
you apparently have never traveled on an Alaskan highway that is snow covering black ice. we dont slow down for much up here... 2wd in those conditions is just asking for trouble and i have seen it many times guy in a 4x4 pickup has it in 2wd and goes to make a pass or speeds up and looses it and goes flying in the ditch.
day in day out 6 months out of the year... dont mind the trailer
Old Dec 12, 2013 | 08:45 PM
BCM's Avatar
BCM
Damn. I was applying the brakes just watching that.
Old Dec 12, 2013 | 08:50 PM
  #28
offroadnt's Avatar
offroadnt
Hey Troverman or maybe another of you guys that know Fords. I have a 2010 F250 and I can't find information for the front hubs, I've put two threads up on here and searched all over the net and even talked to a few dealers. Would you or someone you know have any information on the front hubs for my truck? They don't work at all in auto and it's a bugger to get them to lock up in manual. I was hoping to get some insight into these hubs before I dismantle them. As far as I can tell 2005 through 2010 are serviced as sealed units, the main question is does this include the inner bearings, seals and such for the outer axle assembly? I was under there the other day assessing the front end and I find I can move the ujoints inside the steering yokes up and down a quarter inch, this seems loose to me. Any idea where I can get information on this? Thank you.
OP sorry for hijacking your thread
Old Dec 12, 2013 | 08:52 PM
  #29
Boss08v10's Avatar
Boss08v10
3.23.13 heading to Big Lake - YouTube
You grow up on snow covered roads your whole life and 4x4 and 70MPH fit together just fine. Nice video.
My 2000 excursion was the most stable vehicle I've ever driving on snowy roads.
Old Dec 12, 2013 | 09:51 PM
  #30
Pickupmanx2's Avatar
Pickupmanx2
YUP!!! That's funny right there!
