Sponsored by: Real Truck
eot ect delta
Old Dec 8, 2013 | 12:59 PM
PSDlongbox's Avatar
PSDlongbox
eot ect delta
Just got my torque app running. At idle I am seeing ect of 186.8 and eot of 176.8. After driving around town for about 30 minutes. Are these acceptable?
Note: ambient temp is 22F
Old Dec 8, 2013 | 01:10 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
10F is fine, just watch it to be certain they don't suddenly skyrocket
seems a bit cold, but then again it's 22F outside...so...
Old Dec 8, 2013 | 01:36 PM
jswartz84's Avatar
jswartz84
Around town is no way to check temp deltas.
Get vehicle to operating temp. Get to a place where you can drive for 15 minutes at 65mph on relatively flat ground. Check your deltas(your engine oil temp will be the same as the coolant temp or a little higher). All is done with the vehicle unloaded. Temp deltas up to 15* are acceptable.
Old Dec 8, 2013 | 01:41 PM
PSDlongbox's Avatar
PSDlongbox
OK..I'll take a trip down the freeway
Old Dec 8, 2013 | 01:46 PM
Mcrafty1's Avatar
Mcrafty1
I'm thinking you have them posted backassward......the oil temp is, at least as far as I have ever seen, never colder than the water temp after running that long of a time so if that is the case your temps look great for the ambient temp being what you posted.
Old Dec 8, 2013 | 02:12 PM
PSDlongbox's Avatar
PSDlongbox
posted correctly. Just double checked.
Old Dec 8, 2013 | 02:32 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Thermostat may be open
Didn't notice you said around town. Agree you need to get to about 60mph for at least 10 minutes
Old Dec 8, 2013 | 06:36 PM
acf6's Avatar
acf6
test needs to be done on the highway at 65-70, oil shouldnt be that much colder...
Old Dec 8, 2013 | 06:49 PM
PSDlongbox's Avatar
PSDlongbox
ok, just got back...at 70mph I had 190.4 ECT and 194.4 EOT at cruise and 197.5 was the highest it went when I did a couple WOT pulls from 50-80 back to back.
Old Dec 8, 2013 | 06:50 PM
acf6's Avatar
acf6
sounds fine
Old Dec 8, 2013 | 06:56 PM
PSDlongbox's Avatar
PSDlongbox
I wanted a baseline for right now when it is 15 degrees out vs in the spring/summer. I have been wanting to do a flush and switch to ELC and replace the thermostat when I install my coolant filter. I just don't think I will have time until spring.
Old Dec 8, 2013 | 06:57 PM
acf6's Avatar
acf6
mine has dropped a little. around town , summer or now it stays the same but now on the highway its dropped maybe 1-2 degrees. i usually stay at 190-197/198
Old Dec 8, 2013 | 06:59 PM
PSDlongbox's Avatar
PSDlongbox
around town I was only getting 188.6 degrees for the ECT. I am wondering if I have a slow or open thermostat.
Old Dec 8, 2013 | 07:00 PM
acf6's Avatar
acf6
thats what mine is usually at. actually lately its been around 186-188 on the highway. i dont pay much attention to a 2* difference
Old Dec 8, 2013 | 07:02 PM
PSDlongbox's Avatar
PSDlongbox
I just wrote it off as being 14 degrees outside right now so I am sure it is cooling very efficiently lol.
