Missouri Chapter Join Chapter , Leader:77&79F250
Borderbum's Diesel "Bandit"
Old 04-24-2014, 07:40 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
I'll have more pictures tonight, but the batteries are permanently mounted now. I should have the throttle cable done tonight, too.
  #272
Old 04-25-2014, 09:21 PM
earthquake68
Here ya' go, Jeff. Batteries bolted down and the cables wired in.
Here's the passenger side. I had to make a little bracket to mount the cable junction. I tried it and the dash lights come on with the light switch, and the solenoid clicks when I hit the starter. I still have to wire in the cable from the junction to the starter, but then it should crank.
Don't get excited, I still have lots to do before I try to start it. ...but it's getting closer.
  #273
Old 04-26-2014, 12:05 AM
BORDERBUM's Avatar
BORDERBUM
BORDERBUM is offline
Ill bring you the stuff tomorrow, alt /ac wires and column tomorrow. I won't stay long so I won't bother you!
  #274
Old 04-26-2014, 12:13 AM
BORDERBUM's Avatar
BORDERBUM
Looks good! I yanked more wiring than we need I think...
  #275
Old 04-26-2014, 04:23 AM
whiskey runner's Avatar
whiskey runner
whiskey runner is offline
it is always better to have too much than not enough jeff... looking good alan.. should be smoking real soon
  #276
Old 04-26-2014, 05:47 PM
earthquake68
Here's what I got done today.....
The throttle cable and brackets are made and installed.
The starter cables are installed.
The shifter for the transfer case is installed. (I still need the linkage rod)
The trans cooler lines and trans cooler are installed.
The dipstick tube is installed. (Trans has fluid in it.)
The heater hoses are installed.
I tried to start it by jumping the injector pump, but no dice. I got it to sputter a couple times on either, but I didn't want to use much of that. I tried to start it until I was dumping fuel out of the broken return line on the selector valve, so I just quit. The glow plugs seem to be working too. I'll wire those up tomorrow. .....I guess I need to buy another relay for that. Other than that, it's just about ready to go. Hopefully, tomorrow I'll be breathing diesel fumes.
  #277
Old 05-03-2014, 10:57 PM
earthquake68
Jeff should have some bad video of Bandit firing up today! (woo hoo!!) I hope to be wrapping up this project this week. (hopefully)
  #278
Old 05-04-2014, 04:07 AM
whiskey runner
sounds great alan.. i know it has been a "long and winding road"..
  #279
Old 05-07-2014, 01:50 PM
earthquake68
We're rounding 3rd and heading for home on this one. Bandit now has a column shifted four speed automatic transmission and dual fuel tanks with functional fuel gauges.
What's left to do...
Install rear steel brake line.
Fix a minor fuel leak.
Swap steering wheels.
Add a couple leaves to the front spring packs.
I hope to have pictures and all of this done today. (YAY ME!)
  #280
Old 05-07-2014, 04:31 PM
BORDERBUM's Avatar
BORDERBUM
This is great!
  #281
Old 05-07-2014, 09:13 PM
earthquake68
The moment you've all been waiting for.
Enjoy!
https://www.youtube.com/watch?v=OuAJ...ature=youtu.be
  #282
Old 05-07-2014, 09:17 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,405 Likes on 2,529 Posts
Awesome job Alan, maybe to late to ask, but do you want a actual Ford dash panel with a OEM tank switch? You know I have 1 or 2....
  #283
Old 05-07-2014, 09:27 PM
earthquake68
Here's some stills, too.
The interior with column shifter. (Jeff. Your column didn't work, so I used my column and your steering wheel)
I rehung the fender so it doesn't hit the door and tightened it up. It's all good on this side. I still need to hang the rest of the front clip. (So bring me the hood, Jeff)
Blurry, but this is the t-case shift linkage.
Here's the new shift linkage I made for the trans. It works pretty well.
Another blurry shot, but this is the fuel selector valve. It took a minute to plumb this and get it wired in.
There you have it! It took a little longer than I wanted it to, but it's together now. ....whew!
  #284
Old 05-07-2014, 09:30 PM
earthquake68
This truck had the OEM fuel switch but I couldn't get it to work with the aftermarket valve. This was the best I could do.
  #285
Old 05-08-2014, 07:39 AM
BORDERBUM's Avatar
BORDERBUM
That is awesome!
Quick Reply: Borderbum's Diesel "Bandit"
